I've gotten around 48k miles on this front
48,000, do you wheelie everywhere. You'd be better off with a unicycle.What surface do you ride on, frictionless silk-lined foam rubber??? I don't get that kind of mileage out of car tires, let alone moto tires
I got almost 80k miles on the OEM tires on the car, they told me they were HP models and should only be good for 50k. I'm at 170k on the car now and ready for my second set.I don't get that kind of mileage out of car tires, let alone moto tires
Is that a typo?
Upt'North.
48,000?!?
Is that a typo?
Upt'North.
I was really pleased with my new T31's, over 7000 miles on a set. By that equation you'll use one set to my seven. Although mine were swapped on the right side of legal you naughty boy.I got almost 80k miles on the OEM tires on the car, they told me they were HP models and should only be good for 50k. I'm at 170k on the car now and ready for my second set.
Might be a slight bit under 48k. A month or so after I put it on it got replaced because the installer ripped the bead and I had a slow leak through the sidewall. Do my own install this time.
Did my first oil and filter change a couple of days ago. Ran this oil for over 5300 miles. (Shell Rotella 15w40 and a Fram filter). Used the Fram because I had it already. Probably will go with a K&N next time. Had devil of a time getting the plastic head covers off, but finally did it without breaking anything. Everything else went well with the oil change. While I was at it, I pulled the rear wheel and serviced the splines with the correct moly paste. Checked the final drive oil level and it was OK.
? Should I remove the final drive and use the moly paste on the drive shaft splines? I do this on my Goldwing every few years.
