- Joined
- Feb 11, 2006
- Messages
- 8,455
- Location
- Jacksonville
- Bike
- GL1800 R1200RT NC700
- 2024 Miles
- 028365
I'm sure you can do this but the standard amount of preload available is 36 clicks or 18 turns of the adjuster. Losing 6 turns is loss of 1/3 of the available. If you ride solo with not much cargo the loss of 6 turns is not something that probably matters in regards to being able to set the correct amount of sag for your riding weight unless you are pretty heavy or ride with a passenger. My point is that setting preload affects how much the bike sags under weight of bike, rider, and cargo and we don't all need the entire 36 clicks - that 24 will suffice. If you weigh around 200 lbs or less, ride mostly solo with less than 50 lbs of cargo than 12 available turns of preload is more than enough. It's nice to be able to use all 36 clicks and that is why I started this thread 5 years ago. At that time mine took about 18 turns to start adding preload! 5 years later the play in mine is back up to 2 turns so I just use 2 turns in as the point of zero preload and add turns from there to get the sag I want. At 6+ turns you might be OK to wait until the tech event to remove all the play. For now your shock may have sufficient preload adjustment to get all the performance out of it that is necessary.Thanks for adding these great pics Miansi! I'm a visual learner and seeing these made it so much more clear! I'll probably address this during my upcoming weekend, looks very easy, and after rechecking my adjuster I realized I wasn't getting any real resistance until 6+ full rotations of the knob so I should experience some significant improvement! I was originally planning to wait until the Indiana Tech event.... but this one looks too easy to wait on...
