This whole matter of the rear shock preload adjustment (and rebound adjustment) on the ST 1300 is new to me, this because I have only owned a ST 1300 for a month. After watching the video in the first post (great video!), I attempted to adjust the preload, but did not note any difference when riding the bike.
Earlier this week, I visited Larry (Igofar) in San Jose, and he took a look at my bike. He removed the big black knob assembly that comprises the preload adjuster in the matter that Throttlejocky described in post #47. This was a remarkably quick and simple operation, took about 10 minutes.
He then screwed the knob all the way out (least preload), and used a chopstick to push the piston within the adjustor to the bottom (towards the knob). Then, he turned the assembly upside down, and we discovered that the entire preload cylinder was dry! There was no fluid in it! That was why I was getting no results when I tried to adjust the preload - I was just compressing air, not pushing fluid into the shock.
Larry rinsed out the preload adjuster with hydraulic fluid of some kind, and all sorts of white crud came out (assembly lubricant from the Honda factory, perhaps?). Then, he filled the cylinder with hydraulic fluid, re-installed it, and screwed the preload knob all the way in. That transferred the new fluid into the preload chamber of the shock. He then removed the adjuster, unscrewed the knob, pushed the piston down with the chopstick, and once again filled the adjuster mechanism with fluid. Then he re-installed the adjuster.
Wow - what a difference! Now, resistance was felt beginning with about the 2nd click from the fully extended position of the adjuster knob. There was now sufficient fluid in the adjuster section to make the preload adjustment operate as it was designed to. He set the preload adjustment and the rebound adjustment up to suit my weight (about 180 pounds for me riding solo, plus about 50 pounds of cargo in the panniers and Corbin Smuggler), and I went for a ride... it felt like a totally different bike! The ride was more comfortable and the rear wheel stayed on the ground when going over bumps.
So, for any other ST 1300 'newbies' out there like me, I really encourage you to read this whole discussion carefully, and if nothing else, make sure that the preload assembly actually has fluid in it. It helps a lot to see someone else who is really familiar with the system do the job the first time around... if you are close to California, I encourage you to send Larry a PM and set up a time to visit him. He really knows this system well.
Michael
