Re: ctx 1300
Doesn't say anything about cruise control?????
Is the CTX 1300 gonna be part of the ST forum....has anyone ridin one......they look awesome
It may not be THE replacement for the ST13, but it is A replacement, and from what I can tell, the CTX13 is a modified ST13 and not a new from-the-ground-up bike.Well, I guess it's not intended to be the next ST so comparisons may be out of order. Nice motor, tho.
Well, not really, but we're all entitled to our opinions I guess...CTX13 is a modified ST13
Kinda interesting that that the ST13 is quite the opposite. For 10 years, the moto press complained that the ST13 from the front looked like a maxi-scooter.i agree, the fairing looks funky from side view, but as soon as angle or front view looks much better
Well, OK then. Maybe Honda built a brand new bike that just happens to share a whole bunch of characteristics with the ST13. Like the same apparent chassis dimensions from swingarm pivot location to headstock location. A similar aluminum frame (unlike the CTX700 which is tube steel). The same wheel sizes (rear rim is slightly wider, but 18 inch front is the same. Basically the same brake rotors (rear rotor is larger than the front rotors - an unusual feature of the ST13). The same fork travel and size (CTX13 is inverted). The same footpegs. The same fuel tank location (enlarged for the CTX13 by stretching the swingarm and switching from a monoshock to dual shocks - yes, I know, the upper fuel tank has been eliminated). Basically, the same weight. Clearly, the same engine (reworked for a higher torque, lower top end, lower compression ratio). The same 5 speed gearbox (with new gear ratios) note - not a 6-speed like the CTX700. What appears to the same shaft drive (stretched) with the same final drive. Basically, the same display data (STILL does not have a gear indicator) but with added playlist on the deluxe version. Maybe the ST13 was so good that they couldn't improve on it that much.Well, not really, but we're all entitled to our opinions I guess...
I think that this is dead wrong. Have you looked at pictures of the CTX1300? It is nothing like the CTX700. I am sure that the CTX13 uses the engine as a stressed part of the frame, just like the ST13.The CTX cradles and surrounds the engine in the frame while the ST makes the engine a stressed part of the frame.
From Honda: The basic frame of the CTX1300 is an orthodox double cradle frame in the Frame Overview section. There're pictures there tooI think that this is dead wrong. Have looked at pictures of the CTX1300? It is nothing like the CTX700. I am sure that the CTX13 uses the engine as a stressed part of the frame, just like the ST13.
I stand corrected. Thanks for the link.From Honda: The basic frame of the CTX1300 is an orthodox double cradle frame in the Frame Overview section. There're pictures there too
Someone else pointed out that the foot peg position is more or less the same as it is on the Gold Wing.Will the hump at the rear of the seat give enough support to the lower back to make the bike comfortable for significant distance? I'm doubtful.
Am I missing something...are we not looking at the ST replacement here?
