- Joined
- Oct 26, 2020
- Messages
- 2,027
- Location
- Makefield Highlands PA
- Bike
- 2016 ST1300P
- 2024 Miles
- 013434
Oh indeed sir, indeed.Getting anxious?
I installed a set of auxiliary lights a few days ago.
Nice and clean installation.
I forgot to mention that I replaced the rubber dampers and O-rings in the rear hub, I was surprised at how hard and worn the rubber was.Replaced the rear wheel bearings and flange bearings on my 07 ST1300. Not bad but had over 151,000 miles since last change at 115,000 miles.
Cant tell you if that is a ground block but that pic looks to be from the top of the engine, behind the fuel injection systemUsed a ScotchBrite pad to sand away a ton of white powdery aluminium corrosion from almost every alloy surface, as part of my brother's mistreatment of the bike was leaving it in the salt air near the beach for two years. Plenty of surface rust on steel too.
Believe it or not, this is the final drive casing after the worst was removed.
Dumb question time - I prised open the top of the yellow ground cap and it looked ok, but does the connector split in two like most? It looks like it should, but I couldn't see how to open it.
And is there a second yellow ground cap somewhere? I found this photo but couldn't identify the location. Wondering if this is somewhere under the fuel tank?
Thanks!
Great, thank you... that's one more suspect to eliminate!Cant tell you if that is a ground block but that pic looks to be from the top of the engine, behind the fuel injection system
