Well this will play more like a what did I do with my ST
this week.
Started out with this.
The 1300 is back together after a number of small, but satisfying enhancements - BlueGauges.com dash lighting, LED turn indicators in the mirrors, gear position indicator inside instrument pod, switched high-output triple USB port in the right storage pocket, RAM-dash shelf, handlebar mounted push-button switch for garage door remote, Booster Plug...
To which I got this response
Glade to hear you got it all back together, time for some pictures!
Then today I almost completed my primary lighting upgrades.
So by popular demand, here're the pics from the first round of upgrades.
The garage remote button. Mounted using a
RAM® Motorcycle Brake/Clutch Reservoir Double Ball Base. Destroyed a twist drill trying to drill that lower hole in that stainless. Fortunately I found a totally knackered 1/4" endmill in the shop at work that made short work of it anyway. The empty hole will be where my driving light switch will go once I decide on the mount and the lights. Here's a link to that switch set.
12V LED Motorcycle Switch ON-OFF Handlebar Adjustable Mount Waterproof Switches
This switch for the remote is momentary, the other yet to be installed is latching with a ring that will illuminate when the lights are on. The other one's going on the 1100, which already has PIAA 910 driving lights, so it'll have both switches.
This switch is connected to a remote for my garage attached to the left pocket wall with a 3M Command Performance strip for the time being. That's the connector between the switch and the remote behind the pocket. Ran the wire into the remote, drilled a hole through an unused portion of the circuit board so I could piggy-back the push-button terminals. Works great.
Connected the power leads for this triple USB power port to a switched power from the quartet harness. It works perfectly. Drilling the hole by hand with a step drill was a lot wonkier than I would have liked, but I got the job done. I intend to place a cigarette lighter or a Powerlet socket next to it, but I'll be amazed if I can make them line up after my experience with this one.
Here's the RAM dash, BLUEGAUGES and gear position indicator - inside the instrument pod.
The mirror LEDs
But earlier this week I thought I had everything to pull off the full LED conversion -- Katana headlamps, matching marker lights, amber rear signals lamps, red brake lamps, clear front signal lenses, switchback white/amber lamps for the front, solid-state flasher, even a white LED strip for the license plate.
Yeah, almost.
Those cheap ebay switchbacks that were explicitly advertised for the Honda ST1300. Well they explicitly DO NOT fit. They're so long they hit the inside of the lens before the socket reaches the lamp base.
I started a return request, but the seller asked for dimensions and asked if he could try to source ones that will fit. I'll let him try.
In the mean time I completed replacing all the other lights along with a solid state flasher. Fun fact (that's my kid's favorite conversation starter), the OEM flasher operates at 80Hz with standard bulbs while the aftermarket one at 100Hz regardless of bulb type.
I totally copied
@Obo 's Katana headlight install. I too pulled the headlamp to do it. It only takes a few nuts, bolts and screws to free it.
But the results... Damn those Katanas are bright! Like 'Eye of Sauron' bright. Except without the creepy bloodshot eyeball effect.
I'm very pleased.
Now on the other hand, what were the Honda designers thinking as they made the brake and rear signal lamps? My hands are still sore from trying to extract and then replace those sockets. And the brake lights? How is a rider supposed to replace a blown bulb on the road? Must remove both bags, rear fender, then after a futile 20min or more trying to replace the brake sockets by feel I had to lie on the ground to get them aligned right. And Honda didn't leave a spare millimeter of wire in the loom to ease the task. So I'm hoping replacing these with LEDs is not just a cosmetic and safety improvement, but will also be more reliable in the long run than a conventional bulb.
Oh and while I was replacing the flasher I did uncover evidence of a stowaway from North Carolina in the fuse tray. Glad I found it.
The shakedown ride demonstrated the benefit of the headlamps is as good as I'd hoped.
Next up... Find a way to connect into the tail light circuit for the license light without using a wire tap (hate those) and wait for properly sized switchbacks to complete the job.
That's what I did with my ST
this week.
