No, not yet. I hadn't thought about the fire dept. That could be interesting....Did you get that fixed yet? You could drop by the local Fire Dept. and see if they'd like to give their Hurst tool a little training.
I picked up a set of the Goldwing bars and I have a large vise, I'll have to give this a try!
My friend here in LA converts GWs into Trikes as a side business. Guess its profitable to restore wrecks or old bikes into these
My friend here in LA converts GWs into Trikes as a side business. Guess its profitable to restore wrecks or old bikes into these.
Any chance of your friend making a pair available?
Use a car jack to open them.. preferably a hydraulic car jackAlright, I have the GL1800 tip over bars, but I have a different issue. The bar ends are too close together. I need to spread the bars. Of course, it's impossible for me to physically do that. I'm looking for suggestions on how to accomplish this. HELP! ....please
How did you get the holes to align?when forcing them to align with the step-frame bolt holes.
I don't understand how the holes can be to far apart if the two ends of the bar are touching. The holes in the bars should to close together to match the holes in the step-frame under this condition.How did you get the holes to align?
I squeezed them together with a vice, until they touch but the holes are still a few mm too far apart. It seems that I need to get the bottom part closer to saddlebags. I have not been able to do that with the vice.
Thanks!
If you look at the pictures of these mounted on my bike, see post 86 above, there is clearly a gap between the two ends of the bar. I have not heard of anyone ever having this problem.
What bars are you trying to install?
Are they rear saddlebag guards from a 2012 through 2018 Honda GL1800?
Are you installing them so that they curve forward towards the front of the motorcycle?
Procedure is as follows;
- Compress the two ends of the bar together using whatever method that you have available to you until they are the correct distance apart.
- After protecting the bars, install a couple of worm gear (radiator hose style) clamps and tighten them enough to hold the bars in place at this dimension.
- Install one step-frame bolt, do not tighten completely.
- Rotate the bar until the remaining hole aligns with the remaining step-frame bolt hole and install the second bolt.
- Torque both step-frame bolts to the specification.
- Repeat for the other side.
Note: Do not remove both step-frame bolts of the same side at the same time. This can allow the two frame members to move out of position relative to each other. It can sometimes be difficult to get them back in to alignment.
