- Joined
- Nov 10, 2007
- Messages
- 1,411
- Age
- 61
- Location
- Vancouver, British Columbia, Canada
- Bike
- 1&2&3-2005 ST1300ABS
- 2024 Miles
- 003662
If you want crisp, solid braking, follow the bleeding procedure to a Tee. Honda engineering didn’t place that PCV bleed port there because they had extra money, they placed it there for good reason. Get rid of unwanted air bubbles..How critical is it to bleed the PCV?
The way I envision it, the proportional control valve is at the highest point on the brake tubing, so that’s where the air is going to hang out. If you miss the PCV, you’re gonna have to calculate the tubing from it to the rear bleed nipple, so as the air that was once their at the PCV travels all the way back to that bleeder port and you have to do it quick enough, so the air bubbles don’t migrate back up to the highest point at the PCV.
My recommendation is to use the PCV port in bleeding the system and remove all doubt that the air has been removed from the system.
