Thanks for that Pete. A nice comment to receive. I resurrected the club magazine about 3 years ago, knowing that I had a number of different types of document that I could use to keep it going for a while should I get no contributions from other people. They were written primarily for me - I'm of an age where I can do something to the bike and then a few years down the line I will find myself solving the same problem, hitting the same snags and at the end of it all realising that I had been through the same process before. I started taking photos of things as I did them, and some of them I wrote up - and this process helped the information to be stored away more permanently in my memory.
We decided to remove them from the club mag as they were written as 'how-to' instructions for me. But they read as though I am saying that this is the way to do it, and as the club mag ended up on the internet, perhaps this was not the wisest thing to have out there. I still have them somewhere, but I haven't looked at them for a while. I'll see what I have got. I know I did one on changing bearings (with a video that is on here somewhere), adjusting the valve clearances, and building a fused and relayed accessory wiring harness. There were a few others. I'll find out - I would like to get them all together rather than have them scattered around.
I wrote the 'avoiding the pitfalls' article after all of this, and it was done deliberately in a style which reflects my personal experience and the gotchas that I have come across that didn't seem to be documented in any single place that I could find. I've tried to make it obvious that I am not a trained mechanic advising on the best way to do something - but someone who followed instruction in the Honda manual and still hit problems.
Having said that, one member of the club had his bike in the garage with sticky rear brake problems. Whatever he did, the rear brake kept sticking. The mechanic couldn't fathom out what was going on, and got him mobile again for a club weekend by clamping off one of the rear brake hoses. When he told me, I said instantly that it sounded like his SMC needed a good service. I sent him a copy of the 'avoiding the pitfalls' which he gave to the mechanic. It all seemed to have been a revelation to him.
I think the other articles would need to be revised to adopt the same style - and of course some people have covered the same topics as me and posted them on this forum, and they are much better than my efforts.
Regarding the Shop Manual, I stopped by my local Honda dealer today to order one and the parts guy was a little confused which part number was correct. 61MCS04 or 61MCS14. My ST is a 2007, but I remembered reading somewhere in a post on this site that an earlier version had some mistakes that were corrected in a later edition. Would I be correct to conclude the 61MCS14 one is the most accurate and best one to get?Thanks for the comment, and well spotted.
Can I first of all say that this article - 'Avoiding the Pitfalls' - isn't intended to give advice, nor is it a definitive guide. It is a record of what I do when I service my own bike that others might be interested in. On the very front page I make this very clear and state:
Please take the precaution of using your own skill and judgement and the official workshop manual for your information if you decide to work on your own brakes.
So thank you for checking this out with the service manual. You are quite correct. The service manual states that the stopper bolt should be tightened first - and this is the way that it should be done.
The way that I describe in this personal record is done to suit the way that I work. - eg I like to check that there is no binding between the stopper bolt and the brake calliper created as a result of tightening the rear axle (which may attempt to rotate the caliper bracket clockwise). With the stopper bolt in place but not fully torqued I can check for this.
But you would be right to follow the procedure in the manual - as indicated on the very first page.
Thanks! That helped explain it. I just ordered the 61MCS14 edition from Helm. $64.95 plus $6.00 handling for standard shipping.Mine is an early version 61MCS00 and an addendum to that 61MCS00Z
I did some searching around and cannot find anything on line that distinguishes between the two.
I found an online handbook - the one that comes with the bike - for models in the states. It has extra section that aren't printed in mine. One of these is headed 'consumer information' and it gives the number of the workshop manual. This particular one said 61MCS04 - but goodness knows which model that came with.
There were quite a few significant changes to the ST1300 in 2008, but having said that i am still using my 02 - 04 workshop manual on my 2013 built A9 having used it previously on my A6. We didnt have a 2007 model in the Uk.
Yes there are a few errors in mine - odd torque settings, bearing information, bleeding sequence changed later on, left and right confused - stuff like that. But with a bit of common sense, they can be spotted. As with all things, don't dollow information blindly - especially if it doesn't seem to make sense.
I'd be tempted to start a new thread for this question - it might get replies from more people.
Edit
Aha - someone has just replied to a different thread that i started. Coincidentally, it gives the answer to your question. It seems 14 may be a leter revision - read through all of the posts.
https://www.st-owners.com/forums/th...corrections-to-st-1300-service-manual.142568/
Who's Jeff, by the way ?
