Bit of an update, had limited success on a similar model just removing Signal Ground wire from plug. Code 25 which was a hard fault went away. Tried it on another one no change.
This an ECU from an 03 VFR800, plugs are the same as ST1300 with 26 pins.
VFR 800 doesnt use knock sensor and knock sensing isnt used from factory. But this ECU has the knock sensor amplifier fitted, only 1 though not 2 like ST1300.
Knock amplifier also appears to be a different model/supplier. Hard to see but on the board is also sockets for a second knock amp.
I wasnt surpised to see the knock amp installed but thought there would be 2 of them. Next step is to reflash this ECU with flash from another model (inline 4 with knock sensing)
and see if it works OK. My theory is that Honda makes these ECUs hardware the same but fit to different models with model specific flash/programming .
The CBR 954 ECU also uses 26 pin connectors, dont have one yet to open up, but expecting to find a knock amp as well, CBR 954 engine doesnt use knock sensing.
I guess there may be other Honda 4 cylinder models using the "same" ECU as well from that era. Flashing these isnt easy and interface have to make myself then experiment to communicate with ECU in "debug mode" also known as "the backdoor method". Bought the VFR800 for $20 as an unknown mainly for the connectors and had already been opened up.
Are any of you guys able to open up a ST1300 dead ECU and take some photos for me ? as you are aware even 2nd hand ones are nearly impossible to find.
