After years of conversations and phone support I finally made it to Larry’s place over this past weekend. I have a few issues that need to be addressed, but as Larry said, let’s give the bike a once over. I have been maintaining my vehicles for most of my life, so I thought that I knew what I was doing, but Larry proved me wrong. We spent a full day going through my 2006 ST and Larry found issues that not only surprised me, but also let me know how lacking some of my skills are. The good news is once I am shown something, I don’t need to be shown again. As the day progressed I realized that Larry goes beyond what anyone should expect from the Honda dealer since the amount of time required would be cost prohibitive.
I have the front fork seals leaking along with a slow antifreeze leak. Since I am planning to replace the front fork springs with Sonic 1.1 mm, and since I didn’t come with the parts needed, we decided that this can be done at the next visit. The antifreeze leak also wasn't bad enough to take off the Tupperware during this session.
Some of the many issues that Larry identified was;
front wheel spacer installed backwards (began to damage the wheel bearing seal)-not sure how I screwed this up, but it will never happen again- we replaced the seal and checked the bearings and reinstalled
fork/wheel alignment was off-loosened forks, removed front wheel, adjusted forks so that the axle installed without binding
clutch fluid dirty, lever bushing damaged and needed to be replaced-we replaced the fluid, bled the clutch, and replaced the bushing (going to order a rebuild kit)
all brake pads worn and needed to be replaced-Larry had a set of rear pads that we used. Front brakes will be replaced once the parts are ordered and arrive
found that there was too much oil in the engine (I had recently replaced the oil and filter & I assumed that a gallon container had exactly 1 gallon plus I added the additional .1 for filter, but I now know better)-we removed and then added the oil to the correct level
check the SMC- removed cleaned, lubed and reinstalled. Since this is showing signs of wear, it is going to be replaced
removed the rear wheel, cleaned and checked all components, molly pasted splines, reinstalled rear wheel, brakes, etc.
When we went to start it up, the kill switch (once again) acted up and the bike wouldn’t start until we removed and cleaned it with contact cleaner. A new switch will need to be ordered
As Larry says; I am OCD, which I think is a great attribute to have when performing mechanical repairs. If the dealer spent the amount of time cleaning lubing, checking and verifying each component, their rates would be unaffordable.
It is humbling to be shown how to perform tasks, especially when you believe that you know how to perform them only to discover that you may not have been performing the task correctly.
Larry has a tremendous amount of knowledge on ST1300 models along with general motorcycle and other specific motorcycle model knowledge. I truly appreciate knowing that there is someone that I can contact when needed, discuss issues that I am not confident about and also obtain assistance as needed, especially considering that I had not yet met Larry.
Anyone that is within a ride should reach out to Larry and utilize his talent and knowledge. I am glad that Larry moved to AZ, but remember that this is one of the hottest places on the planet in the summertime.
Additional information to follow.
Thanks Larry!
Thanks Larry!
