Igofar Reviews
I just had my experience with Larry, It is an educational experience but also an experience in humility. Once he gets hold of your bike, he'll finds things that you should have done, but didn't, or things that you did do, but incorrectly. It started after I took my 150,000- mile bike out after the winter. I had done some maintenance but on the first ride, it seemed to me the clutch was not engaging until the lever was almost all the way out. It didn't feel like it used to. It was still rideable, however.
It just so happened that I had an opportunity to be in the Tucson area, so I contacted him to see if he could check out the bike. His first suspicion of the clutch was that is was the clutch slave cylinder. I wasn't sure, but went ahead and bought the parts to bring with me. Over the phone, he had me go through checking out the SMC. Its seemed to work as I've read on her about how it works. It moved a couple MM and the rear wheel did stop when I pressed it in. However, I did have to recently replace the rear disk because its fell under the acceptable thickness. I already had a new SMC on hand, due to the problems I've read here, and also brought it with me.
So, I rode the 1500 miles to his place and my wife drove the "beer wagon". His first inspection, just after I drove up in his driveway showed that the bike was excessivly hot. I knew it ran hot, but had done so for a while, and, from reading about this on this forum, I thought it was just something to deal with. The other thing he found right away is that the left front wheel spacer was installed backwards, and the front tire has some stange wear on it. I had rebuilt the forks over the winter, so this was on me. When he was able to do a more detailed inspection, he also found the upper fork pinch bolts were situated a little to high on the fork tube, clamping down on the threads, but, more importantly, the lower pinch bolts were not tightened, other oversight on my part.
Before I left, I had bled the clutch fluid. I ran several bowlfuls through it. When I arrived at his house, there was practically no fluid in the clutch reservoir! With these three things, it's amazing the bike even made it.
When we got into it, Larry has the tools and experience to do this difficult job without too much swearing. The slave cylinder was not working properly, but didn't look as bad as the one in a previous post. The clutch reservoir had some fine particles in it, as did the brake reservoir. Keeping these scrupulously clean is key to preventing these systems from breaking down. The SMC has a very tiny hole that can get pugged up easily. The slave cylinder is a place where these particulates can accumulate until they gum things up. He also replaced the SMC and we bled all the air out of the lines. He found the rear brake reservoir was almost empty and had drawn down the diaphragm and over-stretched it. He could fit it back in, but it wouldn't vent like it should (something that I would have missed). Fortunately he had another diaphragm available, which we put in. The clutch works well now and the brakes also work, and now I can spin the rear wheel with my foot so it goes through several rotations instead of the 1 to 1 1/2 previously.
Not content to stop there, he wanted to address the heat. He balanced the starter valves, so they were practically even, having to go back and forth, as adjusting one would affect the others. The starter valves are often thought of as affecting only the idle, but, as I understand it, if they are not balanced, then the next step will be off and so on up the line, so it's important to get it all even at the outset. After that, he looked at the PAIR valves. This is not a Honda procedure, and it is possible to mess it up, but, from what we found, at 150,000 miles, it should be a routine procedure. . They were coated with a dark thick organic crud which took a strong solvent and lots of scrubbing (be careful, there is a fine screen inside) to clean and verify that the screens move as they should. The PAIR system is thought of as an emission control system, but if it's not putting oxygen into the exhaust, apparently the O2 sensor reading will be off and this will change the mixture and affect the temperature of the exhaust.
So, the next day I took it on a 600-mile test ride around Arizona. No more hot seat (after i turned off the seat heater!), and I think it it getting much better MPG, but it's hard to say just yet, as I was in a much higher elevation than that in which I usually ride.
A few other things he found: the coolant reservoir bottle was discolored due to heat, and had some small cracks, so far, not dripping, as well as it wasn't fully in its place. It needs replacing. Some very small leaks from coolant hoses- not enough to drip on the floor yet. Also a front fender bolt was missing. Must have fallen out, as I didn't have any left over after maintenance. He replaced the front tire with one I had brought, after he trimmed off all the little rubber mold spikes (hence the name OCD Garage)
He has plenty of old failed parts to show how bad things can get, and many stories about dealer mechanics and obstinate owners. Also knows a wealth of details that would probably escape tyro mechanics such as myself. Things like which way to orient the crush washers on banjo bolts. A great educational and humbling experience. I hope I can keep us the attention to detail that he exhibits and keep the bike running well.
Thanks for the kind words, I very much enjoyed our garage time together, and thank you for allowing me to assist you in keeping your ST in Tip top Shape.
For those looking at the picture of the slave cylinder above, what your looking at is metal to metal wear!
The piston skirt (rubber) started giving up the ghost, and between that and the corrosion along one side of the bore, it was causing the piston to tilt a bit, and the piston was slowly wearing off the surface of the metal on the piston. This is why sometimes the clutch was smooth, and other times it was sticking in the bore not allowing the pressure to move it etc.
You can't rely on the weep hole to tell the story, because often they get clogged up with debris and stuff, and it simply blocks the fluid from exiting where you can see it.
:WCP1:
Igofar reviews:
Larry---
If there is anyway you could put all your past problem history knowledge/expertise of the ST1300 in book form. I would buy a copy.
You should seriously consider this -- you could make a few bucks I'm sure ----:think1:
Maybe just start at the front of the bike --chapter 1 -- and work your way back from there in sequential chapters.---:biggrin:
Igofar reviews:
Larry---
+1. Hell, maybe Tik-Tok that STuff and get the youngsters interested. :rofl1:
Another thankful ST1300 owner here thankful for Larry helping me over the phone and in messages. Not only was he correct but he also made a follow up call to see how things were going. That's going above and beyond expectations. Thank you Larry for everything you do to help the ST community.
Sincerely,
Ron
Forever grateful to Igofar....
You see the way it is when you own and love your bike -- you don't realize what is gradually happening right under your nose over time and miles -- because you listen to the bike constantly and get use to a certain sound. One thinks this is great. But I wanted another set of ears to listen to the bike.
I asked Larry to watch and listen to a video (I posted here on the forum) of my 2007 ST1300 (with 160,240 miles) with the engine running. He sent me a PM (pretty quickly )and said we need to adjust the crank shaft balancers and the bike was making a lot of noise.
I told him I was not comfortable doing that and basically did not know how or what to do.
He quickly PM'd me the white courtesy phone number and said to call him. And so I did.
And now here's the rest of the story,,,,,,,,
Larry immediately told me the step by step procedure and stayed with me on the (speaker) phone while I tinkered away following his instructions.
I proceeded to loosen both upper and lower pinch bolts enough so I could turn them by hand. They were tight and kinda tough to get at but he guided me and I was able to get both pinch bolts loose enough.
Then came time to take a large slotted screwdriver and break free the upper and lower balancer shafts from the pinch bolt brackets, I really felt better having him on the phone ---Then the problem arose--- The top balancer shaft would not break free - no matter how much I tried. Larry said OK --- lets try the lower one then, well with some good effort and patience I was able to free it up enough to get some back and forth movement.
However the top one was seized and not moving. I sprayed both with PB blaster and continued to work on it. No matter what he had me try it just didn't want to cooperate. Well I gave the upper and lower a good dose of PB blaster and we decided to wait awhile before trying again.. So as time passed by I continued to try to loosen the shaft by working back and forth but it was clear it wasn't going to come loose. I waited longer all the time Larry was keeping in touch with me via text and phone calls--- I was giving him updates, ( which were not good).
Then he suggested using acetone and ATF mixture to use as a penetrating solution and so I did this and we continued to wait. As time went by I kept trying although very carefully but it was frozen and not breaking loose. All the time I kept working with the lower shaft keeping getting loosened up even more with the penetrating oil.
It's now getting late around 7:30 pm eastern time and I'm getting discouraged and think I am not going to be able to complete the job due to this. I PM'd Larry and gave him an update that I was not going to get it done tonight. Not too long after that he called me and said to go out and try again. With him on the phone I tried again and no luck.
Larry then told me to put the screw driver on the shaft and attach a pair of vice grips on handle of the screw driver and rotate and hold that pressure on the screw driver to see what happened. So I did and he waited with me and low and behold after about 30 seconds the shaft gave way and I could now rotate it,, woo hooo....
Then I did the adjustment (with his instruction)- Oh and by the way it was out of adjustment-- and then started the bike. I can tell you I noticed an immediate difference.. It felt like it had't for years - then I recall when the bike was new and had that feeling. The engine is noticeably smoother and drastically reduced the rattle noise. When I roll the throttle it feels so smooth --I was dumbfounded.. To think I was just use to it the way it was is an eye opener.
Thank you Larry--- you da man....
ST-Traveler,
Thank you for sharing your experience. Larry awesome! I think adjusting the crank shaft balancers is in my future. I'll have to review my bike history and see if it's ever been done. I believe my ST isn't as smooth as others have described.
Ron
Many thanks to Larry Igofar.
Larry helped me true up my front forks yesterday and this video is the after results.
I did not get the before situation but I can tell you it took a good guerrilla grip and pretty strong forearms just to rotate the front axle about a half of a turn.:mad:
My bike always pulled fairly hard to the right and had some cupping of the front tire-- not much -- but if I took my hands off the grips it would change lanes in about 7 seconds..
With out even knowing Larry inquired about it to me. Oh "of course" the bike drifts I said.. He said "want to fix that ?"-- I said by all means..Please
So he said take off your front wheel and call me back.. And off I went and I removed the wheel and called back...
He said do you have to use a mallet or the palm of your hand to put the axle through or pull it out of the front forks? Embarrassingly I said "yes".:doh1:
Larry said "don't worry we are going to fix that for you today". :run1:
And so Larry took me through the step by step process, which is kinda detailed and I even had to have my wife help at one point (because I only have 2 hands) -- darn it...:rofl1:
We went through the process but my axle was still pretty tight. Through brake line tweaking and bracket adjustments on the forks I was able to nail it.....
To see the video I posted go to the ST1300 tech section and view front suspension thread.
Of course I have some....its just the 3/8 one must be wrong, because its a different size than my SAE 3/8 :rofl1:
OK, let's get back on track here folks, these posts are for reviews, move along, there is nothing to see here :scared2:
Hoses are a pain to install but not if you have spoken with Larry and received his instruction. A dab of anti seize and slicker'n'snot their on.
all i can really say is wow. Larry has helped me soo much since i've joined this forum. he helped me this last time with the SMC install and i'm positive i've never had brake levers this hard before. He walked me through the install in a manner that was easy to comprehend and gave plenty of good tips and tricks. my front brake was mush and he said to zip tie it back overnight . it was rock solid the next day. THANK YOU LARRY!!
Now, on to relearning how to brake effectively now that they actually function as mother Honda intended. they have been barely adequate since i bought it a few years ago.
This review is for Larry, aka igofar:
Wow. Wow. Wow. I've been trying to fix a couple of problems I had after I got "moused" this winter - I was stuck. After one phone call (and one picture) with Larry, I am up and running again with no FI codes. His depth of knowledge is truly outstanding. Furthermore, he gave me several helpful tips and insights along the way to make my riding experience better.
I really appreciate how "gentle" he was with my stupidity. Thanks so much Larry.
If YOU need help, please contact Larry.
Also, thank you for your service to our great country and your city!
Gary
I sent Larry a message about my turn signal problem he called me within a few minutes and we talked through my issue he gave me a few ideas and where to look. It turned out to be a broken ground wire but talking with Larry did help me eliminate some of the possible causes. And thanks to Larry my bike is now ready for a trip starting tomorrow. Larry is a valuable resource and is willing to help out wherever he can.
Thanks again Larry!
I'd just like to add to the grateful sentiments being expressed here. Larry is incredible. He has helped me solve a number of issues that would have been next to impossible to solve on my own. It's not that he's willing to help, he really wants to help. So don't think you're bothering him with questions--you're not.
Thanks again, Larry. One day, when I'm rolling through Arizona I'll need to stop in and show you the machine. :wine2:
