Big_Jim59
New tires installed. Mounted a pare of Shinko 011 Verge Front 120/70ZR18 (59W) Rear 170/60ZR17 (72W).
I also took the time to scrub both wheels with a Scotch-Brite pad and some washing up soap. They are not perfect but at least it scrubbed off a lot of the grime. I also fixed a M6x1.0 screw that was holding the right reflector on the front fender. Everyone knows the proper procedure for cross threading a screw is to crank down until it stops or until you strip out the Allen drive head or in this case both. I just ran a tap through the threads, cleaned them up and presto the screw makes up tight. It only takes a little longer to do it right.
I have a bunch of stuff still to do. I need to pull the fairings back off. Install my USB charger. Pull the air box cover and install a new air sensor. but right now I am sick of having it in pieces and I want to ride it.
