- Joined
- Feb 11, 2006
- Messages
- 8,437
- Location
- Jacksonville
- Bike
- GL1800 R1200RT NC700
- 2024 Miles
- 026983
Don't worry about the rev limiter. The ST1300 will not hit the rev limiter in 5th but it will in 4th at about 130 and a couple of times this has happened and startled me as I thought I was in 5th and not looking at the tach of course I thought something let go in the engine when it cut out. I have done this a few times.Have seen 145 indicated many a time on the ST. Never pushed it to rev limiter because unlike other bikes that only stumble at the limit, the ST seems to nearly kill the engine when you bounce of the limiter (which would be a bit dangerous at a buck and a half).
My ST has a consistent weave at high speeds, but it never feels like it is building and never worries me. A buddy rode it and after a high speed run told me he was terrified by the weave. He was like "that bike has something seriously wrong with it". He was used to a CBR1000RR.
I also have a CBR1000RR which has seen 185 indicated a good number of times, so I know what he was feeling. The 1000RR has HESD (Honda Electric Steering Damper) that makes it absolutely rock solid at all speeds. If you're used to that, I can see how the ST would be terrifying. I guess it's all about knowing your machine.
The weave is hard to explain. On a recent long ride I had the opportunity and the will to see how fast it goes more than one time on the ride. The first time I got a little weave going at a GPS indicated of 125 or so and the GPS recorded a max speed of 128. It went away at 120 then I came back up close to 130 and got the weave again. The tires were 40/42 that morning but I did not have the preload hardened up - it was set for the static sag I like of 1 3/16th". I had some stuff in each saddlebag as well distributed as I could weight-wise. Later in the day I has shed an insulated liner and it went in one saddlebag and when I let the pony run that time it went to GPS 140 steady as she goes. No weave and solid as could be. It just wouldn't pull 141 like it used to but at 55,000 miles I guess she still has most of what she started with. I tucked in as close as I could but it would not lift off 140. That's about 152 on my speedometer. I can't imagine the liner weighed enough to make any difference but it was like two different bikes. There was no wind to speak of and everything else was the same.
