doliven, there is actually no install instructions that I know of ! I wiil give my step by step install
1. Good Idea to lay out all the parts and determine the left and right sides, The header pipes were both the same on mine ,so I don,t get how some members are getting confused !
2. prefit the pipes into the cans to see how they fit and to determine how far in they fit and I would mark a line for final assy ! also check your clamps, the bolts on mine were super long , so I cut some off as to not protrude out too far .
3. When you remove old cans The exhaust gasket may stay in the header pipe or may come of with the can , either way you need them or you can get new ones just to be safe ! The header clamps stay on the bike ,you will reuse those on the new ones.
4. Slip on the new cans and head pipes , leaving all loosely fit !
5. With the bike on center stand , check and measure each time as you tighten things up and line up true and eaqual on each side , this may take a few tries if your picky like me !
6. When you get all lined up, tighten and recheck all .
7. Fire up the beast, check for leaks ,and listen to the sweet sounding growl at low rpms!
8. Go ride
Hope this helps, feel free to PM me if any more questions !
MIKE
