Gene
That's MR CUPCAKE to you!
250llb axle and a 30 lb trailer with a 30-50 lb load sounds like using a daully to go get dinner ?
Posted via Mobile Device
clear as mud?The hubs that would work with these axles would be #204 for a 4 hole with a 4" bolt circle or #205 for a 5 hole on 4 1/2" circle. Then select the trailer tire that you would want to fit which ever bolt pattern you go with. A 4.80 x 8 tire with standard rim and 4 x 4 bolt pattern would be #12110 and 5 x 4 1/2 item #121111
Well when Mark buys a set I'll take the one he dose not use It's the hitch part that I balk at, speaking of which, if these use a pto take off shaft or similar for a coupler, what am I missing here, seems like it would just fall to the right or left when stopped depending on balance of the load. something obvious surely,
Duhh, I knew it had a U-joint I was confusing my self by applying the rotational aspect of a PTO shaft to this application, both ends fixed, movement in only two planes,, move on
Shall I launch my AutoCad and see what we can whip up? Or has ScubaDave do'd that already?
Looks to me like the axle is made to bolt on? Or, can it be disassembled for welding?
The frame could be made asymetrical, flipped top to bottom so either left or right axle could be attached before the ribs are added, single center plane for the wheel. Still similar to what Kreis builds but with the added torsion rubber.
Wow thanks that's crazy helpful. I can take that to a friend that could fab something up like this for me, cause everything you guys are talking about sounds like latin to me.... Anything you would change?
Now if I just had the knowhow and resources to build a box like that cat (Blues Traveler) over on MotoCampers did.
Jeff
That thing is a work of rolling art :bow1:
