You could be right.......
But look on the bright side, you just found an extra 50 horses.
Upt'North.
Holey Moley that looks bad.
Yowza! That's where the green puddles are coming from.
Yuck!! Your MPG will be lots better after changing that!
They're P3 on my '01, too.You know the two “bolts” that hold the side panels on on an 1100? Well, mine are phillips head (1993, are other years different?) and stripped out. Theres a nice 5mm allen screwdriver in my kit, and alot of the other body fasteners are 5mm allen as well, so I bought 2 of the same bolt that hold the tank cover on at the top and some rubber washers at the hardware store to fill in the space, since the shoulder on the tank bolts are deeper. Fits perfect, and looks much better!
Here... try these instead as many of us old timers have (thanks, Warchild!):You know the two “bolts” that hold the side panels on on an 1100? Well, mine are phillips head (1993, are other years different?) and stripped out.
Nice grab on all your ST upgrades. I would think the Super Brace instructions will be almost identical to the MCL.After riding over 6,000 miles with a Corbin Dual Canyon seat I got from the PO, a beautiful seat that just didn't fit me well, I downgraded a couple of weeks ago back to the stock seat. THEN, I upgraded to a Russell Day-Long Saddle that arrived today from RockyHayes!!! I also bought his Rackman Highway Wings and his MCL Fork Brace! I hope Rocky enjoys his BMW! If anyone has the instructions on installing the MCL Fork Brace, I'd appreciate the guidance. From what I've found so far, there seems to be some varying opinions on the fork axle pinch bolts and the fork brace tightening sequence. Thanks!
I put the brace on yesterday! Easy enough, but having the instructions was definitely a help! Took a 150 mile ride this afternoon! See post #334.Nice grab on all your ST upgrades. I would think the Super Brace instructions will be almost identical to the MCL.
How do you like the New seat?
You need an easy up tent for all of your electronics.
+1 A Phillips driver on a JIS screw is asking for trouble.granlund1 said:More than likely not phillips, but JIS screws. People use phillips on JIS screws and that's why they get all messed up.
