- Joined
- Jun 21, 2011
- Messages
- 1,004
- Age
- 71
- Location
- Ada ( Grand Rapids ) Michigan
- Bike
- '07 ST 1300 & '91 GW
What ???? !!I did learn my water pump is leaking into my exhaust.
What brand and part number for the turn signal and brake? LED flasher as in when you apply the brake it blinks a few times before staying on?I installed LED turn signal bulbs, tail light bulbs, and a LED flasher yesterday. Seams to be a lot brighter, especially after I cleaned the tail light lens.
You didn't spend an hour cutting the little mold tits off the tire before riding it?Finally got the new wheels and tires on, after hitting that chunk of concrete at 60+ mph and breaking both of my wheels, and took for a short ride down the street to check the brakes and forks.. all seems fine. Now to gear up and take it for a longer ride and scuff off the tire mold tits off the tire..... !!!!!!!!!! T
You guys out on the far west coast sure do have some funny riding methods. Must be all that fresh air.I tipped it over and then went for a ride.
IMPELLER, WATER PUMPI let a real live motor bike mechanic do valve clearance check on my 04 ST1300 this week. Was last done at 25000. Now almost 80,000. Surprise.... no shims required,all within spec. I did learn my water pump is leaking into my exhaust. Guy says it a big job. About $600 to replace the ceramic gaskets and repair pump. No panic just a slow seep.
No....you are the only one, I know, who does that.....You didn't spend an hour cutting the little mold tits off the tire before riding it?
While that's a great farkle where tolerated by constabulary it more likely an LED flasher module to replace the factory turn signal flasher.LED flasher as in when you apply the brake it blinks a few times before staying on?
I just brought the post up with the part numbers. St1300 turn signal bulbs. The flasher works the same as the stock one just it's made for led bulbs.What brand and part number for the turn signal and brake? LED flasher as in when you apply the brake it blinks a few times before staying on?
Having only 3 bars on the gas gauge helps me as does 42psi in both tires. I haven't done one up yet but a 1" board can be a big help. Roll the rear tire onto the board and it's much easier to put it on the center stand.Hope I can still use the centre stand without blowing a disc.
When replacing the incandescent bulbs with LEDs the much lighter current draw results in the turn signals flashing as somewhere 2x the normal rate maybe more. Most refer to this as hyper-flashing signals. Replacing the stocker with one rated for use with LEDs restores the flash rate to normal.
Some riders prefer the faster rate as they feel it's more conspicuous and makes for increased safety. YMMV.
Had a car merge into my lane and took off the left rear fender of a Honda crv, did much more damage to me and my st1300, 06. I can't bear to look how much needs to be replaced yet, But at least I'm still alive, Thank God for that.
