Thanks fnmag, they will never be forgotten.
With the reservoir fluid level an 1/8" off the bottom, soaked it up with a rag, then swabbed the entire reservoir bowl clean before adding the new fluid.
A tool for every job.....sures makes life easier. We have the technology! The challenge is finding the tool in the garage.
Did the test ride only yesterday. Only have about 50 miles on them. More than likely, the tires won't be broken in until I ride to Shasta at the end of next month for a fitted RDL saddle and seat back for the 09.How's yours doing after the new tires?
Don't you think it's really annoying when folks leave their dashboards bare. Come on Aviator, make an effort
That little gem took nearly an hour to remove. Had a smooth neck between the threads and tapered shank end.Don't you hate it when that happens?
I''ve lost count on how many objects have punctured my tires in the last ten years!![]()
Post #8: https://www.st-owners.com/forums/threads/what-color-engine-paint.143309/Got my '09 ST1300 back from the garage, the irritating water leak fixed and the Turbo Tom rad guard blasted and re-powder coated.
Looking clean and cared for once more, but anyone know of a paint match the engine casing? It could do with a touch up here and there.
The stock wiring is incapable of powering a loud horn to its full potential. Fiamm sells a high tone and a low tone in the Freeway Blaster line. Run heavier gauge wires from an appropriate power source (i.e. fuse block) and install one of each high and low tones and you will sound like a big old Buick coming down the road when you hit the horn button.Better than the anemic "meep, meep" of the stock horn. Not as good as a full-on air horn.
OK - that fairly busy dash (despite what my fellow British Commonwealther Upt’North may say) begs a question that has been bugging me for a couple of years: how do you reach the danged ignition key with all that stuff in the way?
I have an MCL riser and the built-in RAM ball is used to mount a Garmin Zumo plus I like to ride with an SW Motek tank bag. It is a real struggle to get my hand down in there to use the key.
Has anyone found a good way to address that issue?
Pete
Agreed. When I add horns, I connect the stock horn wires and terminals directly to the coil terminals of a relay, and run larger-gauge wires to power, to the horn, and horn to ground.The stock wiring is incapable of powering a loud horn to its full potential.
Thanks, Andrew. I'll try that.The stock wiring is incapable of powering a loud horn to its full potential. Fiamm sells a high tone and a low tone in the Freeway Blaster line. Run heavier gauge wires from an appropriate power source (i.e. fuse block) and install one of each high and low tones and you will sound like a big old Buick coming down the road when you hit the horn button.
