Thanks. Waiting on front pads before installing red brake lever.That red adjustable clutch lever looks good on your ST.
I installed both adj. levers on my ST and am very happy with them.
Watch pot never boils.....
The issue in the US isn't separation between the high and low beams as both aren't on at the same time but between the left and right headlights. With either both low- or both high beams on in an enclosure deemed a single headlight the wattage exceeds that allowed by DOT for a single headlight. So Honda uses a different bulb and base standard as a workaround.Andrew Shadow said:Strangely enough there is not a complete separation between the low and high beam housings on my truck even though they are each in their own reflector assembly- four lamp set up.
As you said, can't really comapre a 4 lamp headlamp to a 2 lamp headlamp or a single lamp headlamp, or car vs bike.
S7.9Motorcycles. Each motorcycle shall be equipped with a headlighting system designed to conform to the following requirements.
S7.9.1 A motorcycle manufactured before September 1, 2000, may be equipped with—
(a) A headlighting system designed to conform to SAE Standard J584 Motorcycle Headlamps April 1964, or to SAE Standard J584 April 1964 with the photometric specifications of Figure 32 and the upper beam aimability specifications of paragraph S7.9.3; or
(b) One half of any headlighting system specified in S7.1 through S7.6 which provides both a full upper beam and full lower beam. Where more than one lamp must be used, the lamps shall be mounted vertically, with the lower beam as high as practicable.
S7.9.2A motorcycle manufactured on or after September 1, 2000, shall be equipped with—
(a) A headlighting system designed to conform to SAE Standard J584 Motorcycle Headlamps April 1964 with the photometric specifications of Figure 32 and the upper beam aimability specifications of paragraph S7.9.3; or
(b) A headlighting system that conforms to S7.9.1(b).
S7.9.3The upper beam of a multiple beam headlamp designed to conform to the photometric requirements of Figure 32 shall be aimed photoelectrically during the photometric test in the manner prescribed in SAE Standard J584 OCT93 Motorcycle Headlamps.
S7.9.6.2(a) If the system consists of a single headlamp, it shall be mounted on the vertical centerline of the motorcycle. If the headlamp contains more than one light source, each light source shall be mounted on the vertical centerline with the upper beam no higher than the lower beam, or horizontally disposed about the vertical centerline and mounted at the same height. If the light sources are horizontally disposed about the vertical centerline, the distance between the closest edges of the effective projected luminous lens area in front of the light sources shall not be greater than 200 mm (8 in.).
(b) If the system consists of two headlamps, each of which provides both an upper and lower beam, the headlamps shall be mounted either at the same height and symmetrically disposed about the vertical centerline or mounted on the vertical centerline. If the headlamps are horizontally disposed about the vertical centerline, the distance between the closest edges of their effective projected luminous lens areas shall not be greater than 200 mm (8 in.).
S7.3.2Type A headlighting system. A Type A headlighting system consists of two Type 1A1 and two Type 2A1 headlamps
A Type C headlighting system consists of two Type 1C1 and two Type 2C1 headlamps and associated hardware
The maximum wattage at 12.8 volts (design voltage): Single filament headlamp, 55 watts on the upper beam; dual filament headlamp, 43 watts on the upper beam and 65 watts on the lower beam.
Type B headlighting system consists of two Type 2B1 headlamps and associated hardware
The maximum wattage at 12.8 volts (design voltage): 70 watts on the upper beam and 60 watts on the lower beam.
A Type D headlighting system consists of two Type 2D1 headlamps and associated hardware
The maximum wattage at 12.8 volts (design voltage): 65 watts on upper beam, and 55 watts on lower beam.
A Type E headlighting system consists of two Type 2E1 headlamps and associated hardware,
The maximum wattage at 12.8 volts (design voltage): 70 watts on upper beam, and 60 watts on lower beam
A Type F headlighting system consists of two Type UF and two Type LF headlamps and associated hardware
A Type G headlamp system consists of two Type 1G1 headlamps and two Type 2G1 headlamps
The maximum wattage at 12.8 volts (design voltage) for the 1G1 and 2G1 upper beam is 55 watts and 43 watts respectively; for the 2G1 lower beam, 65 watts
A Type H headlamp system consisting of two Type 2H1 headlamps and associated hardware
My head hurts now!
I didn't even post the slash dot forms and table!!
If you dont; spell it out explicitly someone won't follow the rules.
Is that 74,999 less.
I said the same recently, I was called, and I quote, "A big Wussy Wuss Wuss".Parked it in the garage until March
Using the Super blue brake fluid, and the clear bleeder hose off the slave cylinder allows good determination of how well the flush progresses. The old yellow fluid runs out and the blue fluid can be seen in the clear tubing.When bleeding the clutch, because of the design of the bleed valve and the slave cylinder, be sure to work the clutch a number of times to get most of the old fluid out. When I pulled the clutch slave out of my 2010 a couple of years ago, the clutch slave was a mess from old fluid. It is pretty hard to get it all out!
Just thought I'd throw that out there for you!
Commuted to work from Seattle to Redmond by motorcycle for the first time in over ten years. ST gets to use the diamond lane on 520, cutting more than 45 minutes off my bus commute (never tried it by car, that's just crazy).
I had forgotten how exhilarating and scary it is to go 55mph in the carpool lane alongside an endless line of cars moving from 0-5mph, will all my senses alert for the ******** who wants to cut into my lane without warning, and always knowing where my escape route is. I'm still wired. Chuffed. It was brilliant. Looking forward to doing it again tomorrow.
Rode to Camborne to see a client, then across to Helston to see another. Torrential rain all the way for 45 miles round trip. Like sitting in a river!! Remembered absent friends lost when the Penlee Lifeboat, the Solomon Browne, went down with all hands in 1981 on 19th December trying to rescue the crew of the Union Star coaster.
