Eau Clairewhat part of the state are you in?
It almost seems that there are more need-mechanicall-help threads and posts about 1300s than 1100s, despite the age range difference. Am I imagining it, or is it true, and an indication of the 1100s' reliability?
I dunno larry. Seems to me like both the 1100's and 1300's are getting old. Add the fact that even a 10 year old ST1300 may be big coin to do major surgery to it, that is why the forum is so busy. Perfect example is a poster posted that the dealer quoted $800.00 labor to replace his cam belt well you can see why people flock to this site. I see it about even. As far as reliability I think its close but I will give the nod to the ST1100 being its simpler and less things to break.It almost seems that there are more need-mechanicall-help threads and posts about 1300s than 1100s, despite the age range difference. Am I imagining it, or is it true, and an indication of the 1100s' reliability?
My VTR1000F takes the 9.48mm diameter shims; haven't turned that into a dirt bike (yet).Both the ST 1100 and the ST 1300 use the 7.48 diameter shims. The other size might be for dirt bikes, I don't know.
Michael
Wouldn't that be a Versys 1000?My VTR1000F takes the 9.48mm diameter shims; haven't turned that into a dirt bike (yet).
That's a lot of shim!Honda lists 69 shims in .025mm increments from:
14901-KT7-013 SHIM, TAPPET (1.200) [7.48mm x 1.200mm]
thru to
14969-KT7-013 SHIM, TAPPET (2.900) [7.48mm x 2.900mm]
Regarding the shim kit, doesn't John O. have one to loan out for the cost of shipping?
Since its rare to need more than a couple shims, and many times you don't need any, seems like buying a shim kit is an unnecessary expense. In the past I just traded them at the local shop where I bought tires, supplies, etc. and they did it for free. Even if you have to buy a couple they're a few bucks each, but I haven't bought them lately so that price may have gone up a bit.
I did the math , I ordered my shim, wait for one week. Shim came in, put everything back together. checked the clearance-- it got tighter-- I did the math wrong ( somehow) took it all back apart. ordered new shim, waited one week. Then it was correct....
Ah, I'm used to SoCal where there's a motorcycle shop on every block, not exactly, but you get the idea. Also, the shims are universal, you can buy them from any dealer or independent shop, they're not Honda specific.
+1 7.48mm for both STs
From whatI have seen in the last 9 months of membership, 1300s are much more complicated (Modern?) than the 1100s so there is more to go wrong! (Wait for the howls of indignation...…!!)
Eau Claire
I think you kinda went off on a tangent with regards to my original point. I was simply stating that if you walk into any motorcycle dealer or shop with your old shim in hand, they should be able to find you the one you need because that shim diameter is/was used by many different bikes. You're not limited to buying them at a Honda dealer.Not Honda specific but there are different diameters. Not every manufacturer uses the 7.48mm. Also different engines use different size shims so they may not have the thickness you need if it isn't something that is common. Also some small engines have an adjustment so no shims are needed. Granted these are not motorcycle engines but the Kawasaki V-Twin that powers my John Deere Tractor(X585) and John Deere Zero Turn (Z950R) both have a bolt I turn to change the gap.
That's good to know- makes it easier. Honda shims it is when the time comes for me.The problem with the non-Honda shim “kits” is the shims are in increments of .050mm, whereas the Honda shims are .025mm. A Honda .025mm is virtually the same as .001” (.0254mm), which is why I highly recommend measuring valve clearances in SAE instead of metric. You can measure finer (metric) but you can’t adjust clearance finer than one thousanth of an inch.
So... a Hotshims .050mm shim increment moves your clearance 2 thousandths of an inch from the extant. With an “in spec” range of only 3 thousandths (.005”-.007”/.009”-.010”) this limits your ability to do the desired job. IMNSHO
I would suspect that now there are probably many more 1300 owners on this forum than 1100 owners. That alone would naturally mean many more 1300 posts as more people are servicing them compared to 1100's. I don't think that is indicative of either bikes reliability.It almost seems that there are more need-mechanicall-help threads and posts about 1300s than 1100s, despite the age range difference. Am I imagining it, or is it true, and an indication of the 1100s' reliability?
I have the Hot Cams kit, forget the product number, but it came in two boxes. I noticed that my 1100 tended to use shims from the thicker end of the range while the 1300 used them from the thinner end. Unfortunately they are the wrong diameter for my Super Tenere, so now I have two kits!
Hi Jamal:
I did a valve adjustment on my ST 1300 this winter - at the same time, I also replaced the thermostat and a number of coolant hoses and clamps.
The process of checking valve clearance is very well documented here in the forum - there are some excellent articles that explain the process in detail, and some downloadable worksheets to assist you. I highly recommend the Microsoft Excel valve clearance worksheet, I found it very helpful.
Here are some "general suggestions" I have for you, based on my experience:
1) If you are going to be replacing the thermostat (implies removing the radiator), then take the front wheel off, take the rad off, and take that whole cover off the front of the engine (clutch cover). It is one heck of a lot easier to turn the engine over and line up the timing marks when you don't have to look through the little holes in the clutch cover! You will need to buy and replace a gasket if you take the cover off, but it is not expensive.
I agree with what you wrote above, and I am the person who suggested removing the front engine cover. But, I didn't suggest that it be removed "just" to do the valve check. The OP indicated that he was going to be replacing the thermostat and "a bunch of other things", and it was because he was planning to do that combination of work that I suggested taking the engine cover off....but removing the front engine cover just to rotate the engine and see the position marks better is NOT a shortcut.
