Tips and techniques are greatly appreciated.
Hi Jamal:
I did a valve adjustment on my ST 1300 this winter - at the same time, I also replaced the thermostat and a number of coolant hoses and clamps.
The process of checking valve clearance is very well documented here in the forum - there are some excellent articles that explain the process in detail, and some downloadable worksheets to assist you. I highly recommend the Microsoft Excel valve clearance worksheet, I found it very helpful.
Here are some "general suggestions" I have for you, based on my experience:
1) If you are going to be replacing the thermostat (implies removing the radiator), then take the front wheel off, take the rad off, and take that whole cover off the front of the engine (clutch cover). It is one heck of a lot easier to turn the engine over and line up the timing marks when you don't have to look through the little holes in the clutch cover! You will need to buy and replace a gasket if you take the cover off, but it is not expensive.
2) Do the valve adjustment before you start the re-assembly of the thermostat area, this because it is easiest to get at the right side cam chain tensioner if you have easy access to the area where the thermostat was removed from.
3) Don't be in a hurry to get the valve adjustment done if it is the first time you are doing it. It took me about 4 hours to do one side of the engine, and 4 hours to do the other side. I'm sure it will be faster next time around, but it is a complex task and there are lots of opportunities to screw up if you try to rush things. I note that you are in Wisconsin, which means you have another 3 months before riding season begins, so no need to rush.
Michael
Location of Right Bank Cam Chain Tensioner
Access Holes for Cranking Engine, Timing Marks
Engine Cranking Bolt, Timing Marks (with cover removed)
(Much, much easier than working through those two little round holes)
