Transforming IGOFARs ST1300 . . . to Shuey's!
Why would you need a monitor system to tell you, when the "shimmy" should have been obvious enough :rofl1:
You don't want a rubber valve stem, they will crack/ break.
Most shops are required to replace the valve stem at every tire change, and as long as you use a good quality SHORT stem, I've never had one of them (Michelin) fail.
I have seen many aftermarket Metal stems fail when the rubber O-rings crack and come apart. And nobody seems to support the metal stem O-rings etc.
Just a thought.
If you need a nice bracket to mount something, you can buy an Oxford Hotgrip Switch Bracket.
You can buy this seperatly .
You can use it left or right. Possible to bend it backwards.
And you get the bolts and washers.
And what is your exact goal with your Pan?
Something like this Goldwing?
Because, I'd like to know there's a problem . . . before the shimmy. Maybe it's just me.
Shuey
The TPMS system will start to warn you when you lose as few as 3-4 lbs. Plenty of time to assess the problem BEFORE the shimmy. Been there, done that.
