Shuey
Never installed quartet harnesses on any of my 3 . . . STs (2007, 2008, 2010).Can these grips be powered through the quartet harness?
Thanks.
I hadn't heard of this brand before.
Shuey
Thanks.
Yes, mine are attached via the quartet harness and have worked fine since spring.Can these grips be powered through the quartet harness?
Thanks.
My poor bike….it’s starting to look like national lampoon Christmas special
What size bolts did you need ? I’ve got some on order. Excited to install them!!Catching up . . .
Bike-Quip (England)
Saddle Bag Tip-Over Bars
The ST1300 designers did a really good job of including the Tip-Over-Wings. If/when the bike falls over they keep the front and sides of the bike from hitting the ground. However . . . with the saddle bags attached, the bags become the 2nd point of contact and accordingly become scratched and/or broken. Adding saddle bag tip-over bars protects them and the rest of the bike.
I used to get these from Bygdog (on our site), but he is definitely 'out of the Tip-Over Bars business.'
These are just as good, really solid and bolt right on without any adjustments.
I think they're a must for any ST owner.
Shuey
PS: I'll try to remember to add another picture showing the bars with the saddle bags mounted.
The correctly sized bolts . . . came with the tip-over bars.What size bolts did you need ? I’ve got some on order. Excited to install them!!
The ST1300s also come to rest on the tip-over wings and the two tires, but . . . sometimes on landing the side case will also get damaged as the "fall" comes to a stop.St1100's rest on the tip bars and the tires, Tupperware stays off the ground. How I know this got lightly rear ended at a stop light, luckily no damage.
or . . . tie down anchor spots on trailers, etc.Got to admit the bars make a good spot to strap luggage to.
I've bought replacement batteries almost exclusively at Walgreens and CVS. As to price . . . they're all expensive now. They last about 2 years mounted on the bike. Supposedly they'll last longer if you take the valve sensors off the tires when you're not riding (thinking winter storage?). I'm lazy and just leave them on all the time. When I want to ride, I want to ride . . . RIGHT NOW!Great idea Shuey. Might give it a try. Thanks for the idea.
I've had trouble finding those specific button batteries anywhere locally. At least for a fair price... (think watch batteries at jewelry store) Not at Walmart etc. No problem on Amazon.
Absolutely. Replacement stems are already in hand . . . and will be installed next tire change.You don't want a rubber valve stem, they will crack/ break.
