I thought it would be easier to add the pre load with the wheel off the ground.Does not matter.
You still have a little bit of air in thereDid this yesterday after watching videos and reading the Igofar 21 step by step process. Previously had 14 clicks and no firmness. Convinced my self to not over think the process and was done in 20 minutes. I did lay a paper towel under the hose fittings and left over night to check for leaks. So far so good. Firms up after 4 clicks.
With the very basic design of this preloader about the best you can do is follow the directions and get it applying preload from .5 to 1.5 turns of the adjuster wheel. I suppose that after following the procedure of filling and reassembling the hose to the adjuster one could lower the adjuster as low as possible so the banjo at the top of the shock is above all of the hose you could crack the banjo loose at the shock end then apply slight preload to push out some oil out at the shock end and purge the banjo bolt and hose of any air in the hose. Refill the preloader piston pump again and see what that last bottom-to-top purge did.Ok, I know this is a very old thread, But some of us are newbys here. As I've stated earlier, I have a new to me 2006 with ZERO maintenance history. With 34k on the clock. I'm going to rebuild the pre-load adjuster as it has "issues" according to all that I've read here. My question is, and if I missed seeing the answer, I apologize.
After the rebuild. At the point of re atteching the supply hose with the banjo bolt & crush washers. Isn't there some air that is traped in the banjo bolt? And a bit in the hose? Even if it's held vertical during the rebuild process? Is it necessary, or possible to purge the air from the adjuster and supply hose after rebuild? Or is it even necessary to worry about?
Thanks Bill
This is pretty much what I thought to be the case. As I couldn't find any conversation on it. Trying to purge the air out of it being a total moot issue. I do agree with you that the rear shockset up being a "low bid" outsource item for Honda.With the very basic design of this preloader about the best you can do is follow the directions and get it applying preload from .5 to 1.5 turns of the adjuster wheel. I suppose that after following the procedure of filling and reassembling the hose to the adjuster one could lower the adjuster as low as possible so the banjo at the top of the shock is above all of the hose you could crack the banjo loose at the shock end then apply slight preload to push out some oil out at the shock end and purge the banjo bolt and hose of any air in the hose. Refill the preloader piston pump again and see what that last bottom-to-top purge did.
My thoughts...... At the end of the day this shock is undersprung for many if not most North American riders. If there is 32 to 34 of the 36 clicks available after servicing there will be more than enough preload travel to set the proper rider sag of 36 to 41 mm but when the rider gets off the bike the shock rebounds to less than 5 mm free sag indicating the spring is inadequate for the rider. You can't make a silk purse out of a sow's ear. Grinding out every molecule of air in the mechanism doesn't change that basic fact.
There is a copper washer between the fitting and body. Use a wrench on the flats of the body and a wrench on the bolt. It is tight but not that bad. The support arm is not as you found out strong enough to loosen the noltThe preload adjuster and the banjo fitting are both aluminum. My experience is that when aluminum is bolted up against aluminum. They have a tendency to "sieze" themselves together. I'd get something to firmly hold the adjuster. Iused a pair of vise grips to gently hold the preload body securely. Put a 10 mm tubing wrench on the banjo bolt. Use a rubber hammer or small dead blow hammer to tap the wrench. That should snap it loose, Mine was on fairly tight.
