Standing by theRight I figure it was mud guard, fork brace and break line support causing some misalignment.
What could be the consequence of this? Need I loosen all that and reset the wheel?
It is to make sure that everything is settled into its proper position
The axle which is clamped to the right fork leg, can be twisted slightly in relation to the left hand fork leg, or the fork legs can be strained slightly - think of the fork leg as a separate component and it is secured to a fixed axle by its pinch bolts. the fork leg is in an upright position, not attached to anything else. The axle is held firmly . It cannot move. Now imagine pushing on the top of the fork leg - trying to move it like a clock hand from the 12 oclock position. You will have some success. Some reasons:
The axle will twist slightly. Yes, metal bars will twist. Think torsion bar suspension, beam type torque wrenches
The moving parts will exhibit some 'play'
The fork leg and tube will bend slightly.
Fork legs were not facing quite the same way - one is pressing on the back of the axle, the other on the front.
Fork legs were not quite level - one pressing on the top of the axle one on the bottom
Those tiny misalignments could be locked in place by friction and the weight of the motorcycle.
As soon as you clamp the left fork leg, the tiny misalignments are locked in place - so before you do that, you bounce the forks a few times to help the components to settle into a more relaxed position. To overcome the friction and take the weight off the front wheel momentarily.
Have you ever seen a motorcyle after a drop. Forks and wheel seem to be twisted, but sometimes they are not damaged. The forks have twisted in their tubes, the axle has rotated on one side, and one fork has compressed more than the other. And the tubes have twisted in the yoke. All that needs to be done is for everything to be undone, rearranged and tightened up again
You must have got on mechanical weighing scales, looked down and thought - thats not right. So you get off and try again. Or you put a foot in the scales and take it off quickly to make sure that the mechanism is free to move. Then you try again and all is well with the world. It shows the correct reading.
What you are doing with the scales is exactly what you do when bouncing the forks. Freeing things up making sure that they are moving properly, before applying the final securing bolts to lock the settings into position.
Now if only weighing scales had such a locking device ...
I’m in the same boat this year (this week in all likeliness). Did it go smoothly ? LMK if there’s anything particular to watch out for since I’ve not done this on the ST1300 before.Very good info. Recently purchased my first ST1300 and it needs both front and rear tires. Ordered tires but stealership wants an arm and a leg to install so I'm going to do it myself. I have more time than money sort of speak and at least I will know that it's done right.
Yes - I suppose so. But if you get it wrong, the wheel ends up out of alignment. 'Alignment' is a state, not a process like turning an adjusting screw.I always took literally the notion of "front wheel alignment" and there is not a such thing on the ST. The right hub shoulder/bearing is the only absolute centering point and there is no optional way to modify it. If I now understand the mounting process correctly, it is more a structural alignment of the front end.
Thank you so much for taking the time for answering my question.
Covered in Honda's standard operating procedures which states;Is axle grease required ? I don’t see anyone mentioning it.
Perfect. Thanks.Covered in Honda's standard operating procedures which states;
Coat the axle shaft with a small amount of grease.
It doesn't state what kind of grease but that isn't critical as the main purpose of the grease is to prevent corrosion, not to provide lubrication.
My recommendation would be any rubber safe water-proof grease, such as automotive wheel bearing grease.
Sure that isn't 0.4974 ?I'm half-OCD
Hi Guys, I've just installed my front wheel after a tyre change and it seems to be OK but I want to verify. The Left side of the bike (as per picture provided by Jheath ) doesn't gel with what I've found (IMG_1133). The diagram given says 4mm whereas I measure a lot more and it goes inward (recesses) I've attached my pictures. As you can see the Left side picture shows the shoulder to be 5.4mm from the wheel axle surface (Non ABS 2003 ST1300). I tried turning this around but it causes the Brake Disk to rub the support strut. When I turned it around it made clearance and the wheel ran free. I was then able to install the brake calipers and lock them in place and they seem to seat well. The wheel turns but has a small amount of resistance once I tightened the axle nut/hex to spec torque (I've lubed everything including bearings). The brakes seem to clamp down correctly.Animated sequence to show the correct procedure when installing the front wheel into the forks of a Honda ST1300.
The right hand side of the bike is the side with the brake lever. Left is the clutch lever side. This is the convention used in the Honda manuals.The video and the photo below are both shown as if looking at the front wheel from in front of the bike. So the brake lever side of the bike is on the left of the image.
The spacers that sit between the fork and the wheel hub can be fitted in 4 different ways, only one of which is correct. The other 3 will cause damage.
Mine are easy to spot from the polishing of the dust seals on the spacer - but beware using similar marks if your bike was bought second hand !
Below are two pdf documents on installing the front wheel and rear wheel respectively.
(Just updated 1 Aug 2020) - 57 downloads of previous versions)
Other related articles:
ST1300 - Fitting Wheel Bearings - What the manuals don't tell.
ST1300 - Front wheel bearing replacement [VIDEO]
