I am going to change brake fluid in a few days. Question: Will the Motion Pro bleeder work on the proportional control valve or should I go by a might Vac???
I don't really understand here. The only Tupperware that needs to be completely removed is the triangular side cover on the right side. You can remove some of the fasteners holding the large middle cowl, leaving the 4 JIS crosspoint screws, and gently pull the rear of it away from the frame far enough to access the proportional control valve. I take a screwdriver handle wrapped in a rag and use it to hold the back of the cowl far enough out to bleed the PVC. I snake the bleed hose for the Mityvac through the opening in the cowl that the valve cover normally occupies.Very good Tech write-up. I tried to figure out how to do this with the manual and it was hard to follow with their diagrams and crummy "photos". This really clears up a lot of questions. I am surprised that Honda did not provide an easy-to-remove access panel so that the rear master cylinder can be checked and filled! It is a little disturbing that so much tuppaware removal is required. Oh well, it is what it is...
