Can that even be done with the engine in place?Pull the head, oil pan......
How would the oil return hole blocked cause it to smoke - excess oil getting in through the valves?
I just did a little checking. You might've beat me to it. Our forum is a great place for help.Very little oil in the air filter (already checked that).
No coolant loss that I can see.
I've already tried 'Marvel Mystery Oil' and it did not help at all.
Like this ?It could just be that the piston rings are stuck in the ring lands on one cylinder. I have had luck using Archoil 9100 in the engine oil at about 1.2 oz per qt or slightly higher on older engine that are carboned up inside or have stuck rings from sitting a long time. The Archoil is a boron additive in an ester base that is known to do a good job of cleaning up carbon and varnish in piston ring grooves without loosening up everything so fast that can clog up filters and oil passages. I've seen some real oil burners completely cured after running the Archoil. Also get some Redline SI-1 fuel system cleaner and add this to your fuel. It will also clean carbon and if you have a gummed up or hardened valve guide seal it can help condition it as well as de-carbon the top end completely. The Redline has PEA in it and also a top end lubricant that breaks down carbon. I think you might be surprised at how well these products can help an older engine.
