That T-stat fits the ST housing, but its rated for higher coolant flow than the OEM/Stant version, so its not the same as the stock stat. I don't recall what Jim's motivation was, but he wanted to try increasing the coolant flow rate.Got some of these coming in from -
RockAuto
Jim Van said they worked pretty well -
Substitute Thermostat | ST1100 Related | ST-Owners.com
Do you think higher coolant flow rate would be a problem?That T-stat fits the ST housing, but its rated for higher coolant flow than the OEM/Stant version, so its not the same as the stock stat. I don't recall what Jim's motivation was, but he wanted to try increasing the coolant flow rate.
I don't know.Do you think higher coolant flow rate would be a problem?
Just curious.
It theoretically shouldn't. If the coolant flows "too fast" it should close the T-stat a bit.Do you think higher coolant flow rate would be a problem?
Just curious.
A T-stat only has direct contact with the coolant attempting to leave the engine. I believe that too-rapid a coolant flow doesn't allow it to stay in the engine long enough to absorb heat.Not necessarily. The coolant can actually flow fast enough to NOT cool down, which would increase the temps. Not enough "dwell" time in the heat exchanger. Highly unlikely however.
The rest of the story after a 'repair' and a 25 mile test ride (mixed and including interstate)-
1. NOT the Evans Coolant
2. NOT the Water Pump
3. NOT the Gauge
4. NOT the Thermostat
5. NOT the Electrical Grounds
6. WAS the Temp Sensor
I don't like to start changing a bunch of parts at one time because you don't know what fixed it if it gets fixed.
So I approached it with one thing at a time.
I did not think the water pump was bad (given past ST1100 personal history at this low miles).
I did not think the new thermostat was bad since the ST1100 ones are usually pretty good (but I still ordered some just in case).
I've never had a temp gauge (or any other ST1100 gauge) go south (Uncle Phil's Parts House had several in stock just in case).
It just so happened that Uncle Phil's Parts House had a brand new Honda OEM temp sensor - 37750-PC1-004.
And Uncle Phil's Repair Shop could work me in and install it (takes a 12 mm wrench and you do not have to drain the antifreeze if you are quick!).
Now the gauge is working as it should (about 1/4 when running down the road and will return there after being stopped in traffic once you get rolling).
My guess is that my original thermostat is still probably good and it was the sensor the whole time - which would explain the inconsistency.
But the previous 'fix' (thermostat replacement) fixed it for 750 miles so I'll have to do more distance riding to see for sure.
As with many things in life, time will tell.
Thanks to all for your input that gave me some great food for consideration and places to look.
I've got about 3-4,000 miles on it at this point and so far I am very pleased with it.Thats great. An update on the Evans in the future would be nice as well once you have some miles on it.
RT
As I said, it's working fine now after I changed the temp sensor.I wonder if some of the [probably lower] core passes in your radiator are getting blocked. I don't know if you're able to get your hand against the cores at various elevations and see if all the heat is in the upper passes primarily in the range between hose connections on either tank end, see if you're short circuiting all of your coolant through a limited number of passes.
I suspect on my 13 [although it looks clean inside and only has 40,000 km] that I have very passive flow in the lower portion of my radiator but I haven't had any problems so far. I've also got a partially blocked heater core in a vehicle; hot coolant in / hot coolant out, blows cold air.
You could also buy an el cheapo [we pay about $25.00 at Princess Auto] IR temp gun and see if your coolant in coolant out temperature difference is lower than normal when you know the thermostat is [or should be] wide open. With an IR you could compare that to another 11 see if theirs has a higher temperature drop [between hose connections] with the stat open.
Bad as it was I drove my Honda Accord twenty-five years / 385,000 km [green meant go] With the possible exception of maybe one half of the original coolant change after crashing the rad [it wasn't me].
