Keep us informed on this Phil. ThanksThe big issue is finding a ST1100 water pump if you need one.
If push comes to shove, I believe there is a gentleman on this board that rebuilds them.
No, manual says to let it snap in place by the tensioner spring and fixate it there.Should I 'force' the tensioner pulley up more (it appears to be fine) or let it be where it came to 'rest'?
I bought this a few years ago as a backupAt this point with my experiences, I have a lot more confidence in the timing belt going way over 100K than I do the water pumps!
Unfortunately it seems HappyBikes (as you know also sold the ABS sensor 'upgrade') seem to have gone shut or stopped their ST1100 stuff.I bought this a few years ago as a backup
I will see if there are numbers stamped on the parts to see if they can still be sourced and will update my post.
Hi Kiltman,The water pump bearing # is WB173007D this seems to be available from different sources for a couple of dollars
The seal is THS 14.20 30.00K. This looks like it’s available at a tractor supply. For a couple of dollars
Hi Kiltman,
Can you advise me of any site that lists that bearing - I have spent hours trawling through bearing suppliers, but cannot come up with that particular number.
Many thanks.
Thanks Kiltman.If you prefix each part number with the item, your search will tend to get you a more local source.
Water pump followed by the number
Water pump seal followed by the number
This is how I narrowed it down.
I don’t want to break the seal on the packaging, later today I will get ID an OD of the parts so they can be cross referenced.
