Welcome... to big service!
rear jug gives easy access, forward one is a nightmare... adjusting the outlet valves requires removal of radiator...
Fortunately all were within specs...
Ditto on t/chains, gliders and spanners...
The NT is generally not really that service friendly... a bit of an origami...
Guess I'm spoiled by decades on the ST1100...
Replacing the coolant required to mutilate the air guide... not in the mood to remove the bloody upper fairing for such a simple job...
New valve cover gaskets & grommets (+ the mandatory dab of RTV on the strategic places
BTW is this the only thing I see some improvement done: those gaskets holding really strong in the grooves and won't fall off the cover...
On the 1100 I always have to tack them on with a thin layer of glue...
As synthetic 10W30 isn't really common here (plenty of dyno and blends around), I'd ordered a can of MOTUL online...
Same brand permanent coolant, BelRay super DOT 4, BelRay hypoid gear oil... the usual...
GF claims the engine is more silent again...
Brake pads will need a few miles to settle and bite properly again...
Anyway, she's ready for the MOT next week, will roll in again for a new set of tires prior the Scotland run late summer...
