I was considering one of these, but now I'll look at one of the cheaper units. Thanks, Andrew!
If the problem that we are seeing with this unit is being caused by the battery and not something else. That is what we don't know.
That is what my theory is. I asked Sena that and of course they would not answer. Would only give a scripted response stating that the unit is not user serviceable and the battery is not replaceable. Part of why I think that their after sales customer support sucks.Is it possible that the battery is bad and won't let it work?
Apparently yes. The plan is to take it a part and see what we can see. If we screw up and brake something so what- It is useless as it is anyway.Is it possible to open up the unit, disconnect the battery and then try plugging it in with the usb?
Possible if the charging circuit or the battery are defective but not as a result of his negligence in leaving it discharged for to long. All of his rechargeable equipment, including the Sena, is kept all in one room in his basement. Every month he puts each item on charge whether he has been using it or not. Part of why he is so angry at Sena. This units failure is due to a defect, not as a result of his negligence or abuse.Since the Sena wasn’t used much, it’s possible that the battery voltage dropped too low during storage. When that happens, no amount of charging will bring it back.
That is what he is planning to do to see if it comes back to life. He was supposed to be looking in to ordering a battery to give it a try.I’d spend the $17.99 at Amazon for a new battery, to see if that helps.
FYI- Any device with rechargeable lithium chemistry batteries is best to be stored about 40% full, and this level of charge could last a year.Every month he puts each item on charge whether he has been using it or not.
The problem with these types of articles is knowing whether it is a good idea to follow their recommendations for a particular product. I have read other articles that stated to always maintain batteries above 90% for long term storage, others that stated never let them drop below 50% and still others that stated it is best to fully charge it and then do not recharge it until it is so discharged that you have no choice. Kind of like the newly rekindled debate about whether red meat is bad for you or good for you. In the end the consumer can't figure out what is the best option for their particular electronic gizmo so I do whatever the manufacturer of that particular item recommends.FYI- Any device with rechargeable lithium chemistry batteries is best to be stored about 40% full, and this level of charge could last a year.
Semi-related... has anyone found a battery for the SMH10 that has the correct connector instead of bare wires? I've replaced the batteries twice in both of my SMH10s, but I keep having to reuse the original connector, i.e. cutting and soldering the wires. I'd like to find a battery that already has the connector.
Well that's pretty much the problem with taking advice from any source– is the advice accurate in a given context or does context affect advice given.The problem with these types of articles is knowing whether it is a good idea to follow their recommendations for a particular product.
Some sources say to charge Li batteries to 80% if they're to be stored long term. Others say 40%. I have no idea which is correct or if there's any significant difference.
Ontario was considering a law something to the effect that manufacturers selling products in Ontario would have to make them repairable and they would have to offer repair parts and manuals to the public tp do so. Did they ever pass that law? Probably not- killed by Doug Ford I would imagine.FWIW - I just enquired with Scala about getting the batteries replaced on my Scala Rider Q3 - and they flat out said that they don't do that since the warranty has expired - and that my only options were to try to do it myself or they offered me a discount code on a new unit. I am not impressed.
What a shame - the unit works great and it does still have some battery life, but it seems to be getting shorter as time goes on.
Pete
I have yet to see where anybody has scientifically and methodically tested any of these theories. I charge mine to 100% before storage, I figure if they discharge faster from the 100% point that they will eventually get to the safest storage percentage.
Ontario was considering a law something to the effect that manufacturers selling products in Ontario would have to make them repairable and they would have to offer repair parts and manuals to the public tp do so....
A long standing peeve of mine is that often, other than some minor broken part X, I have a perfectly good something or other that I can repair easily if I get could part X but of course you can never get the part. It would be nice to not have to throw away otherwise perfectly good items but for lack of some $10.00 part.
Sorry. I have to side with Sena on this. They are a business, and need to make a profit. If they did as you suggest, where do they draw the line?Second complaint is that they would not even consider the claim- they rejected it out-of-hand simply because the warranty period had expired. I understand that the warranty that was agreed to as part of purchasing the unit had expired but there should be considerations made
