I'm in the no weave group with speeds up to about 150 kph I think. There was a bit of pucker factor however. I have a topbox on it as well. Mine is a 2014 so maybe the design was tinkered with enough by then?
That works out to about 93 mph. Aren't most ST1300 owners claiming to have weave that begins at higher speeds than that?I'm in the no weave group with speeds up to about 150 kph I think. There was a bit of pucker factor however. I have a topbox on it as well. Mine is a 2014 so maybe the design was tinkered with enough by then?
Those are my thoughts, exactly. I think that a certain amount of weight in the back is causing a light condition in the front that is exacerbated by lift created by the windscreen shape.Back in 2008 when I was on an autobahn in Germany I tested the ST1300 I was on (which was supposed to have been a police bike).
I saw it at prolonged speeds above 120 mph if the windshield was up at any setting.
You couldn't just run up and back down, you had to stay there for a bit.
If the windshield was completely down it was fine.
I surmised that it had something to do with aerodynamic lift as the windshield does not go straight back, but sort of in a curved fashion.
The ST1300 did have the Hondaline topbox fitted.
It felt like driving an old pickup truck that had too much stuff in the back - the front end got light.
But it seems to have varied from bike to bike AFAIK.
It's governed?I haven't experienced the weave on my Police version, just under its governed speed.
Rob
I met a guy at a get-together a couple days ago who has a late model BMW K1600 that he says has a weave. That bike is governed to just over 100 mph and he thinks the weave is the reason.
The weave is unmistakable when you experience it. The ST feels like is "swimming" with simultaneous roll and yaw motions. The faster the mph once in the weave the higher the magnitude of the roll and yaw. It's not really felt through the bars though the bars are displaced back and forth slightly as the motions are damped.I have noticed that my front tire wears on the side and the rear tire squares up, I know it is normal wear. This will change how your bike handles, but it creeps up on you making it harder to pinpoint the changes.
I have to believe that different contact patches are going to add to any load, suspension settings as well as aerodynamics at higher speeds, I have head shake, I believe from trunk size and suspension settings and speed. Coupled with a headwind.
Changing tires will definitely change output as well as suspension changes, load and distribution and all, or a combination of it All of it put together makes identification of where weave and is caused by can be as hard as why one color is faster than the other.
Harder yet is the personal definition of what is happening, I also have had what could be considered "weave" with the windshield up in a cross wind, it only had to do with the windshield and conditions
Some years ago in the UK,where alot of Police forces were using Pans at that point,there were a number of high profile cases of crashes after weaves.Simply down to too much equipment in the back.The radios needed v heavy batteries then and that,coupled with all the other kit was causing the weaves.Honda quite rightly maintained it wasn,t the bike.Owned my '07 ST1300 for about two months now. Love it! Just came across the "Pan Weave" issue. Don't plan on doing any high speed cruising, (I'm an under 100 mph rider) but would like to hear your thoughts on this anomaly. Looks like it's nothing to worry about if you use common sense - any high speed runs should be done with the wind screen down, light weight in the pans, no trunk and medium rear shock load. Thoughts...
Alan
Isn't that responsibility of the owner? Things like this is what I read the manual for...... without either setting suspension ...
Just curious, what setting is that? The lowest? If so, that should be the least-wobbly setting.Been surprised at number of Pans I have come across with rear suspension still in shipping setting after both years and many many miles after they left the dealership.
Seems dealers in both Europe and North America were sending them out door without either setting suspension, or even mentioning it to new owner
