Yes, I just didn't know which wire had been selected for that purpose, and it doesn't really matter for the purpose of this diagram. It needs to be one that becomes live when the ignition key is turned to 'Ignition' and not when turned to 'Acessories only' The coil draws less than 1A and most circuits / fuses won't have a problem with that.@jfheath the solid green wire / brown wire would be a 12V power source, which may be switched on and off with the bikes ignition.
While I recognize this is something that could be done, I'm running with the fact that SW Motech put more thought in it than I will. Hopefully they were correct in assigning a 12V 40A relay to the task. My musings that it seems excessive are based perhaps on ignorance on this topic.If you want to check fuse/relay sizing or perhaps decide what size relay you need for this application, see below:
1. The 2amp fuse used in the coil circuit... you'll need to know the curent draw of relay coil as the fuse needs to carry 1.25 times that current. You'll get the coil current from relay specs.
2. To size the relay you'll need to know the current pulled by the lights as the relay contacts will carry that times 1.25 as well. Then, you can select the closest size up relay available. The current for the lights should be in the lights specs or labeled on the lights.
As a general note, the current can also be measured with your meter set to Amperes and meter inserted in the circuit (not parallel like when you measure volts).
