I may need to. Keep reading.If you need a hand I am only a few minutes away and have a bit of knowledge .
The green never makes it into the socket. It comes from/ and goes to the switch from point of connection with power from the "switched power source" on the bike.From your pics:
1 - (last pic) the Yellow/Green stripe becomes White at the connector. Can you trace the White make sure it reaches the relay socket, then measure 12V to ground at relay socket, on "that White" with light switch on and connector plugged in? Should 12V be present on that White wire at relay socket, then you're getting signal to turn relay on.
2 - (pic before last) - how many White wires you have there? I'm thinking one White coming from the connector in Line 1; one White coming from Battery; and one White going out to lamps. Can you remove one battery lead and set your meter on Ohms or continuity, then probe all Black wires at socket to Ground for continuity? Then, connect battery back in, set meter on Volts DC, measure for 12V at socket, the other 2 White wires (leave the one tested in Line 1 out). You should have 12V on one of the Whites.
I cannot probe anything in the socket at all, yet.
Your diagram is close. Perfect for the lamps and battery, configured a little different, but explains it the same. The line with the 5A fuse is white, not red. There is no red in fact, except for the short bit between the switch and the first three pin connector.Right - the diagram helps a bit. The 2A fuse is as it should be - that is on the lead that taps into your original power lead to provide a trigger voltage to turn the relay on. A 1A fuse would do for that, but 2A is OK. That wire will go up to the rocker switch and then back down to one of the the relay terminals.
That diagram helps to understand what you have. I cannot work out what colour wires you have, and I cannot bring myself to draw a circuit diagram with a green positive wire !!
But I think that this is what you are looking at - or something very similar. I've tried to guess what is inside the protective sheaths. Your diagrma only shows the combined leads - so it is not much use for fault finding. I hope that this might help. Ive tried to draw things in roughly the same position. The single cables have a white centre. It is not two cables. Its space to colour in the actual cable colour !!
Check it through:
On the left, the power supply for the trigger coil comes from one of those horrible cable splice devices. It comes from a power line that turns on when the ignition is on.
It is fused with a 2A fuse. That is all that line needs - the coil inside the relay draws less than 1A. It is then conencted to a switch. When the switch is on, that passes 12v to one side of the coil. The other side of the coil is connected to the battery earth -and that completes the circuit. The colid has current flowing through it, which creates a magnetic field and that causes the other two contact in the relay to conenct together.
The power from the battery flows through the 5A fuse to one of the switch terminals on the relay . The relay is switched on by the blue circuit. and that sends power to both lamps. They may be connected both on the same relay terminal or joined together in the wiring harness later.
The black lines on the diagram show the connection to the battery negative terminal. THis is shown connected to the relay, and then another wire connects it to the two bulbs.
So that completes the circuit for the headlight.
When the switch is off or the ignition is off. There is no magentic field in the relay coil, so the two contacts separate and turn the headlight circuit off.
I suggest that you try to work out what colour wires are which part of the diagram and label them or colour it in. Then find out which part of it is broken.
I got it apart. But thanks. I may have to put together again and pin it, but I think the relay is shot.What I do... I use a pin needle inserted along the wire into the socket (one wire at a time) until it stops and measure from there (back-probing the socket). I saw the diagram, made a reference to it in one of the posts. And you may not need a relay, it sounds like you're not getting the trigger signal to turn on, but will see if that's true after back-probing.
Added - can you see a securing feature on the socket or the relay that can be pried open with a tiny screwdriver blade? Is the channel on the front face in your pic that feature? Can you see a snap in there?
Theres one difference that I just spotted. Your rocker switch has three wires. Do your lights have hi / lo beam ?
Looks like a 12 V 40 Amp model. Seems a bit big for the job....
The relay looks like the standard one that Honda used to use.
I can understand why you would have two, but why three - where does the other go ??
