I've attached a picture of my new ride that I picked up in Ottawa last week. I rode it home and had a chance to get used to the DCT.
2016 VFR1200X DCT. 35000 km. Good condition. Tires worn out (Pilot Road 6), but they stick good. SW Motech bags and driving lights, engine guards, and footpegs.
I've ordered an aftermarket seat (Touratech), as 8 hours on a stock Honda seat was a little too much. I also ordered a new, larger CalSci windscreen. Grip puppies already added.
Although supposedly mint condition (according to seller) I'm in the midst of fixing the driving lights that don't work. Which means I need to get into the left side fairing where I believe the connections are made. This leads to the bigger problem as the fairing bolt highlighted in the one picture does not undo. It spins, slowly and quite reluctantly, and the parts get hot if you do it long enough, but no "unscrewing". I believe it is crossed threaded together (so it is screwed, both literally and figuratively).
If you look at the parts fiche here I believe it is part # 33 and # 1. With # 33 being the outer cowling bolt and # 1 being the "nut" cast or fitted into a slot in the next cowling behind.
They look like these:
So, my ask is, how do I get this piece undone? Do I pry it open and try to cut the bolt with a oscillating multi tool? There is not a lot of room and I'm not even sure I can get in there to cut it. I took the other side apart, no problems, but also no solutions.
Mike
2016 Honda VFR1200XAC VFR1200X Middle Cowl | Babbitts Honda Parts House
Shop online for OEM Middle Cowl parts that fit your 2016 Honda VFR1200XAC VFR1200X, search all our OEM Parts or call at (231)737-4542
www.hondapartshouse.com
Mike
