Whooshka
Fairly faST old guy
Looks like a different take on BMW's Telelever suspension.
a lot of cornering dynamic are lost but it's a Touring Bike
Ok maybe not a lot but some is. Everything is a trade off .. Sts use 18in front wheels where a 17in would corner better, so they compromise .
These forks separate steering forces from braking forces and allow engineers to precisely tune the fork to feed an allocated amount of braking forces directly into the frame instead of all onto the front wheel. This keeps the fork from being under 100% of the braking forces. A certain amount of dive is desirable because it shortens trail and allows the bike to turn easier under braking but 100% is considered too much by users of them because it can cause a bike that is braked while leaned to stand up and open the turn.Interesting. So what happens when you’re cornering? The geometry of the bike has to be different than with the standard forks?
……………... A certain amount of dive is desirable because it shortens trail and allows the bike to turn easier under braking but 100% is considered too much by users of them because it can cause a bike that is braked while leaned to stand up and open the turn.
Conventional forks might not be the most ideal setup, but their the best compromise, their simple, and cost effective...
All I see are 12 separate pivot points which will wear out and introduce lots of slop into your steering and suspension.
Conventional forks have been around a long time and have been refined to work on the fastest, most advanced race bikes made. For that reason, I think that manufacturers would continue to use them on most bikes as the cheapest, lightest and simplest technology.
Right, and for the sole purpose of "cost cutting" and "adding fancy features that look good on glossy folders" we now have electric power steering with absolutely zero feedback, astronomically expensive to replace and buried so deep inside the vehicle, that you've to remove engine, tranny and the entire front suspension for access...The same thing was said about power steering on cars when it wss introduced, it's unnecessary.
More complicated, more moving parts, heavy, fantastically more expensive, less reliable than forks.
Great marketing.
Sorry....just the old R&M engineering residue I can't seem to forget.
MHO:
- not a really new technology
- increased unsprung weight
- lots of moving parts requiring NASA-grade maintenance procedures
- lots of highly expensive parts in need of replacement in case of an incident
...already "minor damages" will quickly result in a financial write-off/totaled bike...
I mean kudos to the ingenuity, concept, tooling and performance...
But replacing seals, bushings, head bearings or even a bend fork tube on a conventional setup will not force one taking a second mortgage, nor require a laser guided alignment rig for adjustments...
Great marketing.
Damn. I was going to mention electric starter power windows power door locks automatic transmission... "Progress" is always a compromise between vision and "the good ol' days".The same thing was said about power steering on cars when it wss introduced, it's unnecessary.
Only when it's not true. A little spin / hyperbole / hype... That's to be expected. That's not the same as Mr. Haney's spiel though abused it could be.Marketing is snake oil
...be rolling stone wheels down dirt paths with a stick. There'd be no progress if we listened to the "If I don't like it - it can't be good" crowd.Obo said:If we never looked at other things to see if they'd get better with radical changes we'd still
