F2 Review:
This past Monday my left low beam went away. The PO had replaced the stock 45/45 bulbs with 55/65 watt bulbs. I have been trolling this thread for a while as I am a big proponent of LED lights & since I needed to replace the burnt bulb I decided to order a pair of F2's.
I ordered the Safego bulbs off of Amazon for $49.99. Here is the link:
I ordered them Tuesday and received them yesterday (Thursday) and installed them immediately. It was a simple process. I was able to perform the whole process from the top. After turning the bars in the direction of the bulb I was working on I reached down in in front the bar. It was a little snug but a quick process. After removing the offending bulb, I used a flap disc on a grinder and ground away the 2 bottom tabs on the LED. I inserted it in the housing and while trying to manipulate it into position......…......it fell through the hole and into the housing
There I was squatting in front of my STeed staring at the part through the headlight lens. It was laughing at me. Taunting me. The smirk was infuriating
I would not be defeated, however. After a few minutes of quiet introspection (with a short burst of angry expletives
), I had an idea! A sure fire way to remedy this dilemma! I cut a piece of bailing wire about 24" long and bent the end into a shallow "hook". After a few tries and 2 adjustments on the "hook" I inserted the new engineering marvel into the housing through the bulb mounting hole. I hooked it! Now I had to turn it to pull it out the same way in fell it. Hmmm
. Well, The retrieval gods were smiling down on me or were tired of watching mw molest that football because
I got it! This whole fiasco took about 15 minutes. The rest of the install was uneventful and everything went together as it should.
I tested them and everything worked correctly. I tucked away the excess wiring and box and anxiously awaited nightfall. All I can say is WOW!
The pattern of both high and low beams is great and the amount of light they throw down the road is great! I have only had them for one night so I can't speak to longevity, but, if they last, these are definitely the LED bulbs we've been looking for!
I will post updates if any are warranted in the future.
