Now I'm thinking Clutch slave? I think someone else said sticky plates.
Ok. That's good to know. I am letting the bike cool down now. I will see how it goes tomorrow morning when it's cold again.Now I'm thinking Clutch slave? I think someone else said sticky plates.
Hello everybody.
I have just come across this topic. This is very revelant to me. I think the thread has drifted away from the initial question. The problem was that, when the thread starter already had his bike in first gear and as he left the clutch out and began to accelerate away there was a clunk. This clunk could be avoided by leaving the clutch out gently and accelerate gently. It is not the sound the gearbox makes as the bike is being put into gear. I have the exact same problem and after checking the final drive , and finding no problems, I am thinking that it may be the clutch. I have had this problem with some time. Today it has become more serious. There is a crack or clunk coming from the engine region when I start the bike from cold. It makes this sound maybe 6 or 7 times until it heats up. Maybe 10 seconds between each noise. Then it goes away. This has only just happened, so I'm thinking it may be linked to the previous problem. Any ideas?
I think I solved my problem - emphasis on not certain yet. Swapped out the final drive with one I bought on ebay. A 10 mile ride this winter - no clunk. Real test in the coming weeks. Have not taken the original FD apart yet for a PM. That ebay purchase was only 110 w/ shipping. So far, this clunk has cost me a bundle (I did not do all the work myself).
BTW, as my threads say, the second mechanic who worked on my bike used his head and a stethoscope to localize the sound. I heartily recommend this diagnostic tool for everyone - the dealer's guy simply test rode the bike and did his investigating with his ears far far away from the noise.
It will be interesting to hear if replacing the final drive cures this problem long term. If it seems ok after 10 miles , it's probably sorted. Please let us know. I will source a final drive myself if it works out well for you.
Now a year later and a few thousand miles. Yes, replacing the final drive with my $100 used one from fleabay solved the problem. Completely. I've been meaning to take the old one apart and check clearances but one thing or another always seems more important.
I can’t believe my rear end would be cooked after 40k? Legendary Honda? Maybe they addressed something when swapping ?
It’s hard as hell to squeeze the lever
What are you talking about.. it's basically the same as before... use reply, not +QuoteSide note to Joe - if he sees it - why is it a three step process now to get a quote into a post?? AAAARGGHHHH!
Nope.. same number of steps.. but it gives you 2 things to click on .. +quote or reply.. still same number of steps you just have to remember quote doesn't mean here what it meant in the last one... here just use reply.OK, that DOES work, but it isn't like before, when you highlighted only part of a poster's text and got the "quote" word, which when clicked on, put the quoted text into my post. I was going with the old method, which does take more steps to get it into a post. Thanks.
does q
n the
Above I quoted parts of your message to me ... a reply would have quoted the entire message and selecting and using reply would just quote what you selected.t there?
You're reading 'quote' but it's '+quote' with the + sign which means multi quote... here, I'll multi quote several words in above from you ..
