aniwack
It all depends on how cheap the customer is. Don't want the labor cost? Crimps for you!
heat shrink put over a soldered connection when made long enough eliminates the possibility of flexing at the joint. The shrink tube is stiff. Waxed heat shrink is harder to find. There is a coating of wax inside when heated an shrunk the wax oozes out the ends , a perfect seal. There are numerous ways to seal it as long as it is sealed.
Adhesive lined shrink tube is the solution. Not the cheap PVC kind, you want the polyoelfin type. The glue oozes out when you shrink it. Done correctly it's impervious. Under trailers, bilges of boats, etc. It works.
RT
Proper roll crimp with a quality tool on uninsulated connectors covered by quality ($) shrink tubing. Many of mine are 26 years old. Too many to count. JMNSHO YMMV FWIW
No, definitely not. Just a general addition to the thread as a whole. I hadn't seen the tool used be addressed.Sorry, is that directed to my post above Larry?
Not if you want to maintain the watertight integrity of the shrink type connectors. I have a ratchet style crimper for them that definitely doesn't dent. If denting was a requirement I would use non-insulated and shrink tubing.
Are you addressing puncturing of the insulting sleeve?Not if you want to maintain the watertight integrity of the shrink type connectors. I have a ratchet style crimper for them that definitely doesn't dent. If denting was a requirement I would use non-insulated and shrink tubing.
You crimp it before you heat shrinkAre you addressing puncturing of the insulting sleeve?
Yep, I don't want to puncture the "insulting" sleeve of shrink material.Are you addressing puncturing of the insulting sleeve?
That would be adding injury to insult.Yep, I don't want to puncture the "insulting" sleeve of shrink material.
Crimping is mechanically stronger and soldering is electrically superior. There are applications for both. NASA, who knows a bit about vehicle wiring, allows both. Their guidance is on selecting the correct joint type for the application and then executing it correctly. Seems reasonable.
https://workmanship.nasa.gov/lib/insp/2 books/links/sections/407 Splices.html
Absolutely...High vibration, like on a MC - crimp with quality components.
I have had solder connections vibrate apart on me on MCs, before I learned.
The military crimps fighter jets for a reason.
+1 A solder connection can be made fairly impervious to vibration on a bike starting with making it stationary. But high reliability can be achieved more efficiently by crimping with quality tools and bits.High vibration, like on a MC - crimp with quality components.
Stationary - solder.
