Clear lenses for the front turninglights ST1100
Hi all.
Let's be honest this is my very first message and just trying to order those clear turnlight but don't know how to proceed. I live in Belgium.
Have all a nice sunny day.
I hesitated a long time to do this (I guess I suspected it was more difficult to make the conversion)- Ad had ~ 20 sets left for the 1100 when I ordered the second set from him for my 2000 a few weeks back (awaiting them in the mail)- that said, it’s a very easy conversion- all you need is a heat source, some clear silicone adhesive, and the switchback LEDs (white/ amber), and you’re all set.
Plus an LED-compatible turn-signal flasher, or incandescent/LED-compatible if you're not changing the rear bulbs, too.
I used Superbright LEDs on the ST and every other bike that comes through the shop and never had an issue. Great service, accurate specs and easy transactions.
:) well, sort of…
If you do a search on my posts on LED lighting (bulbs?) you should find a list I did of all the parts I used on my 1100.
Part numbers and suppliers are all there.
And in the event I’m remembering something I actually didn’t do, let me know and I’ll post it.
Again… I think. Maybe.
Any advise on a good switchback bulb kit for the ST1100 ?
Yes, kits are available.
You are in Belgium. Does your ST1100 have both running and turn signal bulbs in the front? i.e. Three wires to the bulb connectors. Or does does it only have turn signals? i.e. Two wires to the connectors.
If you have only turn signals, you will also need to replace the connectors for ones with three wires to accommodate both the running and turn signal circuits.
See the below link for a kit that will give you an idea about the three-wire connectors.
ST1100 Switchback Indicator kit Daytime Running Light lightenupgrade
Hi!
I'm a new one here from Switzerland. My name is Tony and I'm 35.
I just bought my first Pan from 1998 few days ago and I'm searching clean indicator lenses, like the one you're selling.
Dou you still have in stock? I want 2 pairs...
Best regards,
T.
Hi all, long time since an update from me.
I manage to make my own switchback indicator kit for only few buck and I want to share it with you.
Parts needed:
-any switchback bulb you can find, orange/white, ebay or amazon or local store.
-a pair of these bulb socket BAY15D, P21/5W lamp holder
I found 'em on Aliexpress. They have 3 wires. They are a bit hard to fit but it works well, no drill or cutting needed.
-Led relay or 2 resistors according to your preferences.
Connect two wires of the BAY15D connectors to the stock indicator + and - and the 3rd cable to the main position light (the small light at the front).
Cannot give you exactly what color cable goes where because cables color of these chinese BAY15D connectors are not always the same .
hi folks, new to this sight and to the st1100. I am trying to buy or locate a clear set of signal light covers, but none of the previously posted links work for me. can someone send me a working link to the vendor or company so as I can purchase a set?
