Michael - I think mine is the opposite, Most of the gasket came off the engine case with the cover. The cover is what I am having trouble with. The gasket is fused into the aluminum and I have tried everything to get it off with not luck.
Also I am finding out that that gasket remover is not available in the states. Must be to caustic? I have to resort to simple green and it ain't workin.
I refuse to use a razor blade for fear of damaging the soft aluminum sealing surface.
Hello:
Well, in a perverse way, you are luckier than I was - when I took the clutch cover off, 90% of the gasket remained on the front of the engine block, and my lower back is still recovering from all the time I spent crouching and squatting when I was labouring to get the remains of the gasket off.
At least you have the luxury of carrying the two parts into the house and working on them at the laundry room sink.
The first piece of advice I would offer to you is "be patient". The weather in Ohio is probably the same as the weather in Toronto, which means you've got at least a couple of months to get the job done, there's no hurry to get the bike back on the road again.
As I mentioned in an earlier post, I found that 'gasket remover' did a good job of softening up the gasket, and if I used a STIFF plaster knife (not a thin flexible one) I could scrape the softened gasket off without rising damage (gouges) to the aluminum.
The product I used (purchased in Canada) is also available in the USA, packaged slightly differently, here is a link to the manufacturer's website:
Permatex. Walmart sells it.
You might also want to consider placing the clutch cover with the gasket side down in a thin pan (cookie sheet, roasting pan) with some light-duty generic solvent in it and letting the gasket soak overnight. That might soften it up. Either way you go about it, you will need to "rinse & repeat" the process several times, so do be patient.
Eventually, though, you will get the remains of the gasket (and Honda's factory adhesive, which is the primary cause of the difficulty) off.
Below are a couple of pictures to provide you with some encouragement.
Michael
Front of Crankcase
90% of my gasket was stuck to this surface
Clutch Cover, after cleaning
