As you said OEM I am assuming that it is a Yuasa AGM. Yuasa states the following;What should I do for the battery? its OEM ordered from Honda service. I won't be using it obviously for a little while. Any suggestions? Battery tender or just leave it in box until I get ready this spring?
Battery Maintenance & Storage
A battery only requires a little monthly maintenance to perform perfectly. Keep the battery charged to 100%, recharging when the lights dim, the starter sounds weak, or the battery hasn’t been used in more than two weeks. Follow the simple battery storage check list below once a month:
AGM Batteries
- Check voltage every 3 months (or more frequently if stored at higher temperatures as high temperatures cause higher self-discharge rates)
- Periodically:
- Keep top of battery clean
- Check cables, clamps, and case for obvious damage or loose connections
- Clean terminals and connectors as necessary
- Recharge battery if voltage is below 12.4V.
- Once activated, the battery is permanently sealed and must never be opened. There is no need to add water to AGM batteries. Adding water to AGM batteries will result in irreparable damage to the battery or the vehicle.
