Wire a trailer with seperate (turn/brake) lights for use as combined lights tooThere is a schematic around here somewhere on making the trailer both 5 and 4 way compatible.
Is the separate brake and turn signal lights what you're referring to?if You are exclusively towing with the ST leave it as a 5 wire, no interface needed to hook to the bike.
The kids on my lawn say this is a sign of my old age as I run them off. I like the growl of certain engine/exhaust combos but the dB level has to be conservative.fnmag said:I also dislike the increased decibel level.
Five wires being ground, tail/marker, brake, left signal, right signal, right?
The trailer has a round plug, which I believe is five wire, so get a matching socket/harness.
Any reason to not just direct-wire without using interfacing relays and a separate fused supply?
When trailers were equipped with all incandescent bulbs the theory was that the (some would say undersized) OEM motorcycle lighting system wiring could not handle the added draw put on it by all of these added bulbs. Now that most trailers are either equipped with LED lighting, or have been/will be converted to LED lighting, this concern is largely gone. There is also the concern that if there is a failure in the trailer wiring you risk loosing the motorcycle's lighting as well leaving you with no lights at all. Isolating the trailer lighting from the motorcycle's lighting eliminates these risks.Any reason to not just direct-wire without using interfacing relays and a separate fused supply?
Just about broke in now!
Ouch! That must've hurt.AV8R said:Passed a milestone.... literally
Play with your nuts?
When it's time to give up two wheels that's not a bad way to roll. It looks great next to that H-D. But if I'm honest its lines and spartan trim don't really match the ST. Matching paint would help some but it looks out of place to me.
However - if it pleases you that's all that counts. Once done I'm sure it will be fine. And of course - pics will be obligatory!![]()
