I have Recently Added a Part 4 as a separate document attached to this post. See a Summary in my post of 4 Nov 2017.
I wrote this document over a year ago when I first got my Zumo 590. It was driving me nuts in that it didn't behave how I expected it to behave. So I tested it, tried to find out when it went wrong and why, noted apparent changes in the way that Zumo define the way in which routing points are treated during navigation. Basically, I shook it until it started behaving itself.
No - that's unfair. My Zumo behaves exactly as it did before, but I understand it better, and I know how to avoid the numerous traps that present themselves between planning a route and clicking 'Go' on the Zumo. And this is what the attached document is about. Loads of screenshots to illustrate the points, and hopefully written in a way that makes it clear.
The issues discussed are peculiar to the recent Zumos that have the Trip Planner App - like the 590, 595, 390, 395. But there is stuff in here that is also relevant to the way in which Mapsource and the Zumo 500 series work.
There are 5 files attached. The first is the full document of 4 parts - 35 pages.
I've also split it into the 4 separate sections:
Part 1 is to do with routes and how the Zumo treats the different type of routing points when navigating.
Part 2 is a complete route together in Basecamp and getting it to work correctly in the Zumo. There is a lot to go wrong - this will fix the issues.
Part 3 is a reference section for both Basecamp and the Zumo. A series of "How To" descriptions - focusing on the things that go wrong - including why the carefully planned route ends up as something different in the Zumo; how to clear those unwanted routes, favourites and trip logs; Basecamp's 'Ghost' Points; ..... stuff like that.
Part 4 is New 4 Nov 2017. It is to do with Profiles in Basecamp and how the Zumo repsonds to them. See my post of 4 Nov 2017 for more details and a summary.
Thank You! I wish I'd found your document earlier. It took me two+ years of experimentation and frustration to figure out how to build a reliable route for my 590. I can now get it right about 95% of the time but your explanations will make that easier and let me understand how to use options I've avoided rather than risk problems. This is information that Garmin should have provided with every current GPS and Basecamp.
