I will take some and upload them tomorrow night.Any pics you could share??
It will quit leaking,,,,when it's empty.Put the last piece of Tupperware on the bike after the 300,000 mile refresh. Water pump, tensioner, idler roller, timing belt, all new water, air, vacuum and fuel hoses, both coils, valve adjustment (first time on bike. Four were off), synced carbs, output shaft seal, cleaned and painted swing arm, swing arm bearings, replaced rear final drive (worn teeth), new rear tire, new rear brakes, shimmed up worn side stand, new fuel filter, cleaned and dielectric grease on connectors and oil / filter change). Looks like my shifter seal is leaking. Looks like the rear case will need to be removed to fix this. Not sure if the engine can stay in the bike. May have to leak for another 5 years or so.
Do a search on the site. Seems to me someone here has changed this seal and if memory serves me correctly, they didnt have to take the motor out/apartPut the last piece of Tupperware on the bike after the 300,000 mile refresh. Water pump, tensioner, idler roller, timing belt, all new water, air, vacuum and fuel hoses, both coils, valve adjustment (first time on bike. Four were off), synced carbs, output shaft seal, cleaned and painted swing arm, swing arm bearings, replaced rear final drive (worn teeth), new rear tire, new rear brakes, shimmed up worn side stand, new fuel filter, cleaned and dielectric grease on connectors and oil / filter change). Looks like my shifter seal is leaking. Looks like the rear case will need to be removed to fix this. Not sure if the engine can stay in the bike. May have to leak for another 5 years or so.
So true, and it would also eliminate the need for a 400,000 mile refresh.It will quit leaking,,,,when it's empty.
Put on a set of genmar risers. Only lost two of the little caps that sit in the bolts to the interior of the bike somewhere. Lifted the tank, shined a light everywhere I could, shook the bike.....they're gone. I swear that bike eats tiny finicky parts. However, the risers are on and looking forward to trying them out.
On a completed unrelated topic, anyone know where a person might source some bolt ca......tiny finicky parts......for a friend?
