I was just researching this today and it seems as though BMW released a new version of the strip to fix the issue. I've only had my '08 GS for a couple of months and not much time to ride so I don't know if it will be an issue, but it seems to work properly for now. I think this is the part, but don't quote me:3 months ago I installed the HPOskam fuel strip emulator in my '07. It was about $55 delivered from Europe. I had been watching the fuel strip die a slow death for a couple of months prior. BMW owners with bikes equipped with fuel gauges that get data from a fuel strip immersed in the fuel tank are aware of the high probability the strip will fail at some point and strips often fail fairly quickly.
You will need a GS-911 (or equivalent) to replace the fuel strip as it needs to be calibrated before installation (not that they are very accurate anyway!). Just FYI.If mine goes I'll check with the local dealer to see if I should tackle it myself or not. They seem pretty cool.
Last month while at NatSTOC, I rode KBiK up Spearfish Canyon for breakfast at Cheyenne Junction.
Shot this video with the 360 deg lens on my Insta360 One R camera mounted on a stalk on the handlebars.
I’m with you on the pirellis , I lost track of how many sets I’ve went through, my mileage on them 7k to 8k on the rear and always changed the front at the same time. When I got the bike it had new pr2 which got me 11k next set was pr3 but the front end didn’t feel right, so I went though the front end , fork seals bushing steering bearings still wasn’t right after 3k miles , planing a long trip new pr4 were installed but at 60 to 75 miles per hour sometimes you could feel rear of bike wasn’t right, bike was in the shop for two weeks they checked everything finally they took the rear Michelin tire off and put my first pirelli angel gt on problem solved.After approximately 1000 miles on the Road 6 GT's I am mixed on their characteristics. I replaced a set of Pirelli Angel GT 2's which I really liked as they stuck like glue in the corners and in the wet. They inspired a ton of confidence, but the mileage was pretty lousy. It would have been about 5000 miles on the rear but that was cut short due to a puncture. I found that the Road 6's are a bit slippery in the corners under hard braking and acceleration, at least on my K1600 GTL which is close to 1000 lbs including the large rider. To the point where I got a little concerned a couple of times. I never had that concern on the Angel GT 2's, but I am sure that I will get a lot more miles out of the Michelins. What's my point? Yeah, I got nothing either.
That is the strip that in not available. It's a good part number and it did replace an earlier version but it's NLA. I've read that later R12GS models went back to a float sensor and it may be retrofit to earlier models but some electronic doodad is required because the float sensor's signal is reversed and a full tank reads empty and vice versa when fitted to earlier bikes.I was just researching this today and it seems as though BMW released a new version of the strip to fix the issue. I've only had my '08 GS for a couple of months and not much time to ride so I don't know if it will be an issue, but it seems to work properly for now. I think this is the part, but don't quote me:
If mine goes I'll check with the local dealer to see if I should tackle it myself or not. They seem pretty cool.16141600132 - Fuel level sensor 2003-2014 BMW-Motorrad | BMW Motorrad USA
Genuine OEM Fuel level sensor (16141600132) for select 2003-2014 BMW-Motorrad motorcycles at an affordable price!www.shopbmwmotorcycles.com
