Re: ST1300 Rostra Cruise Control Installation
The 4 amp fuse you used is an inline one you installed I take it? Not already on the bike?
I've never hooked up a relay in my life before. Can I use this 20amp relay in this application?
http://easternbeaver.com/Main/Elec__Products/Relays/relays.html
Also would buying this harness simplify life for me to install this Rostra cruise?
http://easternbeaver.com/Main/Bike_Specific/Honda_ST/honda_st.html
If I use this do I still need the additional 9 pin connector. I haven't pulled anything apart yet so at this point I am assuming the other end of the quartet harness is 9 pin
Thanks!
Leon
Hook up 12V with a 4 amp fuse to the Black w/Yellow wire on the Gold Wing switch.
The Brown Rostra wire needs to be hooked up to a 10 amp switched circuit. I used a relay that is turned on by power from the Quartet Harness.
Thanks!
Leon
