Most of the problems with oil filter removal are because they were put on too tight. You shouldn't use a oil filter wrench to tighten the filter. Lightly oil the gasket and turn it until the filter touches, then turn it another 1/2 to 3/4 turn , usually by hand.
Anyone know the part number for the metal end piece , for filter loosening?
It sure is an awkward spot to try and get my strap tool onto.
I don't know the part number for the filter I bought, but it came from Advanced Auto Parts chain.
Sure didn't work for me, it slipped as I said... but someone had put that filter on too tight. I had even brought the NEW oil filter (existing filter was also the correct Honda part) with me, to make sure I got the filter "socket" that fit.
As has been said in this thread, I have never torqued to spec ANY oil filter, on ANY vehicle I've ever owned, and have never had an oil leak as a result. One of the many reasons I like to do my own work... the service team won't be around when I need to get back in there and do something.
Poor picture of my oil filter socket, but you can see where I even tried the electrical tape inside, to make for a tighter fit. I think they're pretty generic, as I saw the same attachment for the same price at Advanced, made by two different manufacturers. I couldn't see any difference between the two brands, in terms of fit (tried both on my new filter), finish, or steel quality.
That said, I'm sure there IS a difference between all the ones available.
In any case, the oil filter I removed was simply installed unnecessarily tightly. No reason for that at all.
In the end, I'm calling this a WIN. Got it done, learned what NOT to do next time, learned a lot about how the tupperware pieces are connected to each other, and I ended up with ZERO leftover plastic pin bits or steel screws.
Which reminds me - just like on the Blackbird, these plastic push-pins are gonna age and break, so I had better go ahead and order a handful of the different sizes / forms.
Anyone have an illustrated parts diagram for this beast?
Still haven't ordered a service manual. Note to self...
And thanks again for all the response, advice, and shared experience. I appreciate you all.
#WINNING
