Sadlsor
Yeah, it's a question(-s) about the plastics removal.
Thought today I could surely change the oil in 2 hours, having never done it on this bike. Epic FAIL.
I likely took off a lot more tupperware than I had to. Firstly, I removed the little maintenance lid, but couldn't get the valve cover off, fearing breaking it, so I attempted to take off the whole right side panel, figuring it out as I went. (What is the real purpose of that "maintenance" lid anyway? Doesn't give access to squat!) Ultimately couldn't get it off, but loosened it enough to remove the right cover, in order to access the oil filler cap.
Next I couldn't get the old filter off. Tried it on the center stand, tried it on the sidestand - my big ole paws just can't get a good grasp on it, tucked so close to the exhaust as it is. I have an appropriate-sized filter wrench, but there's not enough room to even turn it a quarter turn before the handle runs into something.
Sooner or later I'll get it off, but I know I could do it easier and simpler, with the wisdom of you good folks.
There's a LOT of pages of Tech posts as you know, so ...anyone have a saved link to the best / easiest way to change the oil? I must have 30 plastic pins, plugs and screws out at this point.
Searching for oil change eliminates the word "Oil", as it is so common on the forums.
I'm blathering.
What I should have asked:
1. How much plastic must be removed to perform a complete oil and filter change?
2. Is there a step-by-step guide on here with pictures?
Thanks, all. I won't be torquing this new oil filter as tight as that last ham-fisted dude did.
I'm blathering.
